ASUS F550 HDD Replacement
  1. ASUS F550 HDD Replacement, ASUS F550 HDD/Ram Cover Removal: step 1, image 1 of 2 ASUS F550 HDD Replacement, ASUS F550 HDD/Ram Cover Removal: step 1, image 2 of 2
    • Remove the battery, using release clips.
    • Ensure device has no residual power by attempting boot once battery is removed.
    • Remove either 2 (or 4 for a full teardown) 12mm phillips screws, then removing the bottom cover to gain access to the HDD and RAM.
    • Remove HDD and RAM cover
  2. ASUS F550 HDD Replacement, HDD: step 2, image 1 of 1
    • Remove 3 5mm Phillips screws
    • Slide HDD caddy back, remove using the black pull tab.
  3. ASUS F550 HDD Replacement, HDD Removal from Caddy: step 3, image 1 of 1
    • Remove 4 Phillips screws, 2 per side
    • Remove HDD from caddy.
5 other people completed this guide.
Ryan
1,519 Reputation
14 Guides authored
1 Guide Comment
What is the spec of the hard drive? SATA 2.5"? Any max capacity or other restrictions on what drops in?
mrgilbe1 - Reply
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 16
All Time: 6,571
