ASUS F555UA-EH71 Battery Replacement
  1. ASUS F555UA-EH71 Battery Replacement, Keyboard Panel: step 1, image 1 of 1
    • Remove the ten 18 mm screws holding down the outer shell of the laptop using the Phillips #000 screwdriver.
  2. ASUS F555UA-EH71 Battery Replacement: step 2, image 1 of 2 ASUS F555UA-EH71 Battery Replacement: step 2, image 2 of 2
    • Use your fingers to gently pry open the gap between the silver and black parts of the casing.
    • Separate the keyboard panel from the body of the laptop by wedging the iFixit Opening Tool in between the keyboard panel and the body.
    • The teeth of the casing should make a clicking noise as they’re pulled apart.
  3. ASUS F555UA-EH71 Battery Replacement: step 3, image 1 of 1
    • Gently open the casing until the white, silver, and gold power strips are visible. Gently peel the strips from the bottom side of the laptop.
    • Disconnect the two cables connecting the keyboard panel to the laptop.
  4. ASUS F555UA-EH71 Battery Replacement: step 4, image 1 of 1
    • Remove the keyboard panel from the laptop.
  5. ASUS F555UA-EH71 Battery Replacement, Battery: step 5, image 1 of 3 ASUS F555UA-EH71 Battery Replacement, Battery: step 5, image 2 of 3 ASUS F555UA-EH71 Battery Replacement, Battery: step 5, image 3 of 3
    • Use the Phillips #000 screwdriver to remove the eight 4 mm screws holding the battery in place.
  6. ASUS F555UA-EH71 Battery Replacement: step 6, image 1 of 2 ASUS F555UA-EH71 Battery Replacement: step 6, image 2 of 2
    • Carefully remove the battery from the device.
2 other people completed this guide.
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 23
All Time: 1,080
