ASUS K200MA-DS01T Back Panel Removal
  1. ASUS K200MA-DS01T Back Panel Removal, Back Panel: step 1, image 1 of 2 ASUS K200MA-DS01T Back Panel Removal, Back Panel: step 1, image 2 of 2
    • With the opening facing you, flip the laptop over and remove the following screws from the back panel:
    • Six 4mm Phillips screws using a Phillips #0 screwdriver.
    • One 12mm Phillips screw in the center using a Phillips #0 screwdriver.
  2. ASUS K200MA-DS01T Back Panel Removal: step 2, image 1 of 2 ASUS K200MA-DS01T Back Panel Removal: step 2, image 2 of 2
    • Using a plastic spudger, remove the two rubber stoppers closest to the hinge to reveal the screws underneath.
  3. ASUS K200MA-DS01T Back Panel Removal: step 3, image 1 of 1
    • Remove the following screws:
    • Two 4mm Phillips screws using a Phillips #0 screwdriver.
  4. ASUS K200MA-DS01T Back Panel Removal: step 4, image 1 of 3 ASUS K200MA-DS01T Back Panel Removal: step 4, image 2 of 3 ASUS K200MA-DS01T Back Panel Removal: step 4, image 3 of 3
    • Using a plastic spudger (and a fair amount of force), pry the back panel up from the keyboard to separate.
    • You may have to use one spudger to wedge between the back panel and keyboard while using another to pry it open in a different spot.
Haleigh St. Paul
239 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 13
All Time: 209
