ASUS K43SV SSD Replacement
  1. ASUS K43SV SSD Replacement, SSD: step 1, image 1 of 1
    • Disconnect the ASUS k43sv laptop from the external power supply before starting.
    • Place the laptop on a flat table with its back facing up.
  2. ASUS K43SV SSD Replacement: step 2, image 1 of 1
    • Slide the latch on the right side of the battery on the back of the laptop to the right to the unlocked position.
  3. ASUS K43SV SSD Replacement: step 3, image 1 of 3 ASUS K43SV SSD Replacement: step 3, image 2 of 3 ASUS K43SV SSD Replacement: step 3, image 3 of 3
    • With your left hand, slide the latch on the left side of the battery to the left and hold it.
    • With your right hand, slide the battery out of the battery compartment and place the battery away from the laptop.
  4. ASUS K43SV SSD Replacement: step 4, image 1 of 2 ASUS K43SV SSD Replacement: step 4, image 2 of 2
    • Remove the two screws on the bottom of the laptop using a Phillips #0 screwdriver.
  5. ASUS K43SV SSD Replacement: step 5, image 1 of 3 ASUS K43SV SSD Replacement: step 5, image 2 of 3 ASUS K43SV SSD Replacement: step 5, image 3 of 3
    • Slide the hard disk compartment cover towards you with both hands and remove it from the laptop.
  6. ASUS K43SV SSD Replacement: step 6, image 1 of 3 ASUS K43SV SSD Replacement: step 6, image 2 of 3 ASUS K43SV SSD Replacement: step 6, image 3 of 3
    • Remove the four screws from the hard drive support arm using a Phillips #0 screwdriver.
  7. ASUS K43SV SSD Replacement: step 7, image 1 of 3 ASUS K43SV SSD Replacement: step 7, image 2 of 3 ASUS K43SV SSD Replacement: step 7, image 3 of 3
    • Lift the plastic sheet on the left side of the hard drive slightly by hand.
    • Remove the hard drive and its support from the hard drive compartment.
  8. ASUS K43SV SSD Replacement: step 8, image 1 of 3 ASUS K43SV SSD Replacement: step 8, image 2 of 3 ASUS K43SV SSD Replacement: step 8, image 3 of 3
    • Remove the four screws on the side of the hard disk support using a Phillips #0 screwdriver.
3 other people completed this guide.
Duanrui Liu
303 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 56
All Time: 2,240
