ASUS MeMO Pad 7 (ME572C) Speakers Replacement
  1. ASUS MeMO Pad 7 (ME572C) Speakers Replacement, Rear Panel: step 1, image 1 of 2 ASUS MeMO Pad 7 (ME572C) Speakers Replacement, Rear Panel: step 1, image 2 of 2
    • Make sure your device is turned off. Then with a plastic opening tool, carefully remove the back panel by carefully working your way around the perimeter.
    • The panel will be glued on and requires pressure to open.
  2. ASUS MeMO Pad 7 (ME572C) Speakers Replacement: step 2, image 1 of 3 ASUS MeMO Pad 7 (ME572C) Speakers Replacement: step 2, image 2 of 3 ASUS MeMO Pad 7 (ME572C) Speakers Replacement: step 2, image 3 of 3
    • After removing the rear panel, use a plastic openning tool to remove the frame of the tablet.
    • Start in the middle of the top side and insert a plastic opening tool between the screen and the frame.
    • Carefully run the plastic opening tool along all the edges of the tablet.
  3. ASUS MeMO Pad 7 (ME572C) Speakers Replacement: step 3, image 1 of 1
    • When you take the rear panel and the frame out, place the rear panel and the frame away from the device.
  4. ASUS MeMO Pad 7 (ME572C) Speakers Replacement, Battery: step 4, image 1 of 3 ASUS MeMO Pad 7 (ME572C) Speakers Replacement, Battery: step 4, image 2 of 3 ASUS MeMO Pad 7 (ME572C) Speakers Replacement, Battery: step 4, image 3 of 3
    Tool used on this step:
    Buy
    • Disconnect the ZIF connectors to release the data cables holding the battery in. Use tweezers to do this.
    • You can also use your hand to remove ZIF connectors.
    • ZIF connectors are delicate so be careful when you are removing them.
  5. ASUS MeMO Pad 7 (ME572C) Speakers Replacement: step 5, image 1 of 1
    • Find the place where the battery connector is. Disconnect the battery connectors by carefully pulling up on them using a spudger or plastic opening tool.
  6. ASUS MeMO Pad 7 (ME572C) Speakers Replacement: step 6, image 1 of 3 ASUS MeMO Pad 7 (ME572C) Speakers Replacement: step 6, image 2 of 3 ASUS MeMO Pad 7 (ME572C) Speakers Replacement: step 6, image 3 of 3
    • Using a plastic opening tool carefully pry the battery loose. The battery is glued to the pad; slight pressure will be needed to remove the battery.
    • The casing of the battery is soft and can easily tear. Tearing can lead to the chemicals in the battery to leak out.
  7. ASUS MeMO Pad 7 (ME572C) Speakers Replacement, Motherboard: step 7, image 1 of 2 ASUS MeMO Pad 7 (ME572C) Speakers Replacement, Motherboard: step 7, image 2 of 2
    Buy
    • After removing the battery from the device, locate the volume connectors on the side of the device.
    • Using tweezers, carefully remove the volume connectors and place it to the side.
  8. ASUS MeMO Pad 7 (ME572C) Speakers Replacement: step 8, image 1 of 2 ASUS MeMO Pad 7 (ME572C) Speakers Replacement: step 8, image 2 of 2
    • Locate the GPS antenna. Pry off the GPS antenna cable with a spudger.
  9. ASUS MeMO Pad 7 (ME572C) Speakers Replacement: step 9, image 1 of 2 ASUS MeMO Pad 7 (ME572C) Speakers Replacement: step 9, image 2 of 2
    • Locate seven 2mm Phillips #0 screws attaching the motherboard to the pad. Remove the screws with a Phillips #000 screwdriver.
    • Place your screws somewhere you will remember they are at.
  10. ASUS MeMO Pad 7 (ME572C) Speakers Replacement: step 10, image 1 of 1
    • Once all the screws are taken out, you can remove the motherboard. Carefully, take the motherboard out with a plastic opening tool.
  11. ASUS MeMO Pad 7 (ME572C) Speakers Replacement, Speakers: step 11, image 1 of 3 ASUS MeMO Pad 7 (ME572C) Speakers Replacement, Speakers: step 11, image 2 of 3 ASUS MeMO Pad 7 (ME572C) Speakers Replacement, Speakers: step 11, image 3 of 3
    Buy
    • Locate the speaker connector on the motherboard.
    • Using tweezers, carefully remove the speaker connector.
    • After removing the speaker connector, you can easily take the speaker out.
    • Because the speaker is on the motherboard, be careful not to damage any other parts.
    • There are two speakers on the tablet
  12. ASUS MeMO Pad 7 (ME572C) Speakers Replacement: step 12, image 1 of 3 ASUS MeMO Pad 7 (ME572C) Speakers Replacement: step 12, image 2 of 3 ASUS MeMO Pad 7 (ME572C) Speakers Replacement: step 12, image 3 of 3
    • Locate the second speaker on the left side of the tablet.
    • Locate three 2mm Phillips #0 screws attaching the speaker to the pad. Remove screws with a Phillips #000 screwdriver.
    • While you are removing the screws, do not put pressure on the tablet. You may damage the touch screen.
  13. ASUS MeMO Pad 7 (ME572C) Speakers Replacement: step 13, image 1 of 3 ASUS MeMO Pad 7 (ME572C) Speakers Replacement: step 13, image 2 of 3 ASUS MeMO Pad 7 (ME572C) Speakers Replacement: step 13, image 3 of 3
    • Locate the speaker connector on the side of the device.
    • After removing the speaker connector, you can easily take the left speaker out.
Efe Guldogan
860 Reputation
4 Guides authored
USF Tampa, Team 14-23, Meier Fall 2015 Member of USF Tampa, Team 14-23, Meier Fall 2015
USFT-MEIER-F15S14G23
4 Members
14 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 1,087
