ASUS MeMo Pad FHD10 Battery Replacement
  1. ASUS MeMo Pad FHD10 Battery Replacement, Battery: step 1, image 1 of 2 ASUS MeMo Pad FHD10 Battery Replacement, Battery: step 1, image 2 of 2
    • Make sure that the device is turned off as a precaution.
    • Unplug the charger and remove any memory card you may have in the device.
    • Wedge the plastic opening tool between the front and back cover on every side.
    • Slide the plastic opening tool back and forth to make sure that the back cover is disconnected.
    • Once disconnected, remove the back cover from the device screen.
  2. ASUS MeMo Pad FHD10 Battery Replacement: step 2, image 1 of 2 ASUS MeMo Pad FHD10 Battery Replacement: step 2, image 2 of 2
    Tool used on this step:
    Buy
    • Remove the protective copper sticker and all tape fixed on the device.
    • Using tweezers, remove the ribbon cable from their connections attached to the motherboard.
    • While using the tweezers, make sure to use minimum force and precision to avoid damaging any components.
  3. ASUS MeMo Pad FHD10 Battery Replacement: step 3, image 1 of 2 ASUS MeMo Pad FHD10 Battery Replacement: step 3, image 2 of 2
    • Remove the four 2 mm Phillips #00 screws holding the battery tray in place.
  4. ASUS MeMo Pad FHD10 Battery Replacement: step 4, image 1 of 3 ASUS MeMo Pad FHD10 Battery Replacement: step 4, image 2 of 3 ASUS MeMo Pad FHD10 Battery Replacement: step 4, image 3 of 3
    • Locate the battery cable attached to the motherboard. Using the same technique used on the ribbons, do the same with the battery.
    • Remove the battery from the device. Once removed, use the plastic tool to separate the metal frame from the battery.
    • When separating the metal frame, be sure to hold on in the center as the battery is two separate cells.
5 other people completed this guide.
Dmitry
391 Reputation
3 Guides authored
USF Tampa, Team 9-5, Blackwell Winter 2015 Member of USF Tampa, Team 9-5, Blackwell Winter 2015
USFT-BLACKWELL-W15S9G5
4 Members
10 Guides authored
One Comment
Where i can get new battery for this tablet?
Night Knight - Reply
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 21
All Time: 9,731
