ASUS N56JN Laptop Hard Drive Replacement
  1. ASUS N56JN Laptop Hard Drive Replacement, Hard Drive: step 1, image 1 of 3 ASUS N56JN Laptop Hard Drive Replacement, Hard Drive: step 1, image 2 of 3 ASUS N56JN Laptop Hard Drive Replacement, Hard Drive: step 1, image 3 of 3
    • To prevent injury, make sure the laptop is unplugged before removing the battery.
    • To prevent data loss, make sure the laptop has fully shut down before removing the battery.
    • Pull the switch on the back of laptop in the direction of the arrow.
    • If done correctly the battery should pop out. Lift the battery to remove it.
  2. ASUS N56JN Laptop Hard Drive Replacement: step 2, image 1 of 2 ASUS N56JN Laptop Hard Drive Replacement: step 2, image 2 of 2
    • Use the screwdriver to remove the rubber cap on the top of the backplate.
  3. ASUS N56JN Laptop Hard Drive Replacement: step 3, image 1 of 3 ASUS N56JN Laptop Hard Drive Replacement: step 3, image 2 of 3 ASUS N56JN Laptop Hard Drive Replacement: step 3, image 3 of 3
    • Remove the screw that was uncovered.
    • Pull the backing plate away from the laptop.
    • This will take a fair amount of force.
  4. ASUS N56JN Laptop Hard Drive Replacement: step 4, image 1 of 3 ASUS N56JN Laptop Hard Drive Replacement: step 4, image 2 of 3 ASUS N56JN Laptop Hard Drive Replacement: step 4, image 3 of 3
    • Remove the four screws located in the corners of the metal bracket.
    • Three of the four screws are the same size. The exception is the bottom left screw, which is significantly shorter. Make sure to put the short screw where it belongs when re-assembling.
  5. ASUS N56JN Laptop Hard Drive Replacement: step 5, image 1 of 3 ASUS N56JN Laptop Hard Drive Replacement: step 5, image 2 of 3 ASUS N56JN Laptop Hard Drive Replacement: step 5, image 3 of 3
    • Push the hard drive away from the center until fully disconnected.
    • Lift the hard drive from the bottom right tab to remove it from the laptop.
  6. ASUS N56JN Laptop Hard Drive Replacement: step 6, image 1 of 3 ASUS N56JN Laptop Hard Drive Replacement: step 6, image 2 of 3 ASUS N56JN Laptop Hard Drive Replacement: step 6, image 3 of 3
    • Remove the four screws on the side of the hard drive and bracket.
  7. ASUS N56JN Laptop Hard Drive Replacement: step 7, image 1 of 2 ASUS N56JN Laptop Hard Drive Replacement: step 7, image 2 of 2
    • Remove the hard drive from the bracket.
  8. ASUS N56JN Laptop Hard Drive Replacement: step 8, image 1 of 2 ASUS N56JN Laptop Hard Drive Replacement: step 8, image 2 of 2
    • Insert the new hard drive into the bracket.
To reassemble your device, follow instructions 1-6 in the reverse order.
8 other people completed this guide.
Sebastian Jordan
308 Reputation
1 Guide authored
Cal Poly, Team 14-6, Green Fall 2015 Member of Cal Poly, Team 14-6, Green Fall 2015
CPSU-GREEN-F15S14G6
5 Members
6 Guides authored
2 Comments
That’s not rocket science - How to clone the disk properly? that’s the part I can’t manage… Any freeware clone software that actually WORKS and is not just a dumb backup software…?
Günther Haschberger - Reply
The free version of Minitool Partition Wizard is very good.
Edward Falk -
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 17
All Time: 14,165
