ASUS Padfone X mini Station Battery Replacement
  1. ASUS Padfone X mini Station Battery Replacement, Battery: step 1, image 1 of 1
    • Insert the plastic opening tool between the edge of the screen and the back cover.
    • Gently pry them apart. Use hands to pull them apart if necessary.
  2. ASUS Padfone X mini Station Battery Replacement: step 2, image 1 of 2 ASUS Padfone X mini Station Battery Replacement: step 2, image 2 of 2
    • Remove the three pieces of tape that secure the battery and its wires. Peel gently so you don’t damage any wires.
  3. ASUS Padfone X mini Station Battery Replacement: step 3, image 1 of 3 ASUS Padfone X mini Station Battery Replacement: step 3, image 2 of 3 ASUS Padfone X mini Station Battery Replacement: step 3, image 3 of 3
    • Disconnect the ribbon from the motherboard by gently pulling with your fingers.
    • Using the opening tools, pry the battery off of the adhesive.
    • Be careful not to pull the battery out right away. The ribbon cable is tucked beneath another wire.
Alexzander Pastore
389 Reputation
3 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 17
All Time: 516
