ASUS Padfone X mini Station Front Camera Replacement
  1. ASUS Padfone X mini Station Front Camera Replacement, Front Camera Lens: step 1, image 1 of 1
    • Insert the plastic opening tool between the edge of the screen and the back cover.
    • Gently pry them apart. Use hands to pull them apart if necessary.
  2. ASUS Padfone X mini Station Front Camera Replacement: step 2, image 1 of 1
    • Use a Phillips #00 screwdriver to remove the three 2.5mm screws that secure the speaker case to the motherboard.
    • Remove all tape covering the screws before removing them.
  3. ASUS Padfone X mini Station Front Camera Replacement: step 3, image 1 of 1
    Tool used on this step:
    Buy
    • Use tweezers to remove cover sticker on the dock station.
  4. ASUS Padfone X mini Station Front Camera Replacement: step 4, image 1 of 1
    • Use a Phillips #000 screwdriver to remove the six 0.6mm screws that secure the dock station case to the motherboard.
  5. ASUS Padfone X mini Station Front Camera Replacement: step 5, image 1 of 1
    • Flip the device upwards.
    • Gently push the right side of motherboard down away from the dock station.
    • Do not push the motherboard so hard as it is still attached to a connector. Excessive force applied might cause external damage to it.
  6. ASUS Padfone X mini Station Front Camera Replacement: step 6, image 1 of 2 ASUS Padfone X mini Station Front Camera Replacement: step 6, image 2 of 2
    • Use tweezers to detach the camera from the motherboard.
Nuri Syahirah Mohd Safian
133 Reputation
1 Guide authored
One Comment
I can not get my back off the device at the top of it it doesn't want to complete separate.
Jannell A McDonald - Reply
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 10
All Time: 186
