ASUS Padfone X mini Station Speaker Replacement
  1. ASUS Padfone X mini Station Speaker Replacement, Battery: step 1, image 1 of 1
    • Insert the plastic opening tool between the edge of the screen and the back cover.
    • Gently pry them apart. Use hands to pull them apart if necessary.
  2. ASUS Padfone X mini Station Speaker Replacement: step 2, image 1 of 2 ASUS Padfone X mini Station Speaker Replacement: step 2, image 2 of 2
    • Remove the three pieces of tape that secure the battery and its wires. Peel gently so you don’t damage any wires.
  3. ASUS Padfone X mini Station Speaker Replacement: step 3, image 1 of 3 ASUS Padfone X mini Station Speaker Replacement: step 3, image 2 of 3 ASUS Padfone X mini Station Speaker Replacement: step 3, image 3 of 3
    • Disconnect the ribbon from the motherboard by gently pulling with your fingers.
    • Using the opening tools, pry the battery off of the adhesive.
    • Be careful not to pull the battery out right away. The ribbon cable is tucked beneath another wire.
  4. ASUS Padfone X mini Station Speaker Replacement, Speaker: step 4, image 1 of 1
    • Use a Phillips #00 screwdriver to remove the three 2.5mm screws that secure the speaker case to the motherboard.
    • Remove all tape covering the screws before removing them.
  5. ASUS Padfone X mini Station Speaker Replacement: step 5, image 1 of 3 ASUS Padfone X mini Station Speaker Replacement: step 5, image 2 of 3 ASUS Padfone X mini Station Speaker Replacement: step 5, image 3 of 3
    Tool used on this step:
    Buy
    • Use tweezers to remove the three pieces of tape that are covering the metal.
    • Insert the metal spudger beneath the speaker case and wedge it upwards to remove speaker case from the device body.
  6. ASUS Padfone X mini Station Speaker Replacement: step 6, image 1 of 2 ASUS Padfone X mini Station Speaker Replacement: step 6, image 2 of 2
    • Use tweezers to detach the connecter from the motherboard.
Alexzander Pastore
389 Reputation
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 7
All Time: 182
