ASUS Q302L Display Replacement
  1. ASUS Q302L Display Replacement, Back Case: step 1, image 1 of 1
    • Make sure the laptop is disconnected from a power supply and is TURNED OFF.
    • Use a Phillips #0 screw driver to remove all ten 10 mm screws around the back of the laptop.
  2. ASUS Q302L Display Replacement: step 2, image 1 of 3 ASUS Q302L Display Replacement: step 2, image 2 of 3 ASUS Q302L Display Replacement: step 2, image 3 of 3
    • Wedge a plastic opening tool under the rear case near the hinge.
    • Pry around the outer edge to release the plastic clips holding the rear case to the laptop.
  3. ASUS Q302L Display Replacement: step 3, image 1 of 1
    • Once the cover is free from all the clips, remove the cover from the laptop.
  4. ASUS Q302L Display Replacement, Battery: step 4, image 1 of 1
    • Use a Phillips #0 screwdriver and remove all five 5 mm screws securing the battery.
  5. ASUS Q302L Display Replacement: step 5, image 1 of 3 ASUS Q302L Display Replacement: step 5, image 2 of 3 ASUS Q302L Display Replacement: step 5, image 3 of 3
    • Gently wedge a plastic opening tool under the connector.
    • Pry only on the connector not the socket itself or you risk damage to the motherboard.
    • Carefully lift the connector up away from the socket to disconnect it.
  6. ASUS Q302L Display Replacement: step 6, image 1 of 2 ASUS Q302L Display Replacement: step 6, image 2 of 2
    • Once the screws and connector are removed, simply pull out the battery from its place.
  7. ASUS Q302L Display Replacement, Display: step 7, image 1 of 2 ASUS Q302L Display Replacement, Display: step 7, image 2 of 2
    • Use a Phillips #00 screw driver to remove the five 10mm screws at the hinges.
  8. ASUS Q302L Display Replacement: step 8, image 1 of 3 ASUS Q302L Display Replacement: step 8, image 2 of 3 ASUS Q302L Display Replacement: step 8, image 3 of 3
    • Peel back the tape and remove the two connectors.
  9. ASUS Q302L Display Replacement: step 9, image 1 of 2 ASUS Q302L Display Replacement: step 9, image 2 of 2
    • Pull up on the black tab to remove the connector that connects to the motherboard.
    • Unplug the hard drive cable from the hard drive.
    • Carefully remove the cables from the track that they run through.
  10. ASUS Q302L Display Replacement: step 10, image 1 of 2 ASUS Q302L Display Replacement: step 10, image 2 of 2
    • Carefully remove the display from the rest of the laptop.
2 other people completed this guide.
Nicholas Lozier
302 Reputation
2 Guides authored
IUPUI, Team S2-G4, Harley Spring 2019 Member of IUPUI, Team S2-G4, Harley Spring 2019
IUPUI-HARLEY-S19S2G4
3 Members
2 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 13
All Time: 1,308
