ASUS Q302L Hard Drive Replacement
  1. ASUS Q302L Hard Drive Replacement, Back Case: step 1, image 1 of 1
    • Make sure the laptop is disconnected from a power supply and is TURNED OFF.
    • Use a Phillips #0 screw driver to remove all ten 10 mm screws around the back of the laptop.
  2. ASUS Q302L Hard Drive Replacement: step 2, image 1 of 3 ASUS Q302L Hard Drive Replacement: step 2, image 2 of 3 ASUS Q302L Hard Drive Replacement: step 2, image 3 of 3
    • Wedge a plastic opening tool under the rear case near the hinge.
    • Pry around the outer edge to release the plastic clips holding the rear case to the laptop.
  3. ASUS Q302L Hard Drive Replacement: step 3, image 1 of 1
    • Once the cover is free from all the clips, remove the cover from the laptop.
  4. ASUS Q302L Hard Drive Replacement, Battery: step 4, image 1 of 1
    • Use a Phillips #0 screwdriver and remove all five 5 mm screws securing the battery.
  5. ASUS Q302L Hard Drive Replacement: step 5, image 1 of 3 ASUS Q302L Hard Drive Replacement: step 5, image 2 of 3 ASUS Q302L Hard Drive Replacement: step 5, image 3 of 3
    • Gently wedge a plastic opening tool under the connector.
    • Pry only on the connector not the socket itself or you risk damage to the motherboard.
    • Carefully lift the connector up away from the socket to disconnect it.
  6. ASUS Q302L Hard Drive Replacement: step 6, image 1 of 2 ASUS Q302L Hard Drive Replacement: step 6, image 2 of 2
    • Once the screws and connector are removed, simply pull out the battery from its place.
  7. ASUS Q302L Hard Drive Replacement, Hard Drive: step 7, image 1 of 2 ASUS Q302L Hard Drive Replacement, Hard Drive: step 7, image 2 of 2
    • Unplug the hard drive from the connector.
    • Use a Philips #0 screwdriver to remove all four 5mm screws holding the hard drive metal mounting bracket.
  8. ASUS Q302L Hard Drive Replacement: step 8, image 1 of 1
    • Use a Phillips #0 screwdriver and remove the four 5mm screws on both sides connecting the Hard Drive to the mounting bracket.
    • Remove the Hard Drive from mounting bracket.
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 33
All Time: 2,000
