ASUS Q324UA-BHI7T17 CPU Fan Replacement
  1. ASUS Q324UA-BHI7T17 CPU Fan Replacement, Battery: step 1, image 1 of 1
    • Remove all 10 Phillips screws on the backplate.
    • All 10 screws are 0.55 inches and 20 mm in diameter.
  2. ASUS Q324UA-BHI7T17 CPU Fan Replacement: step 2, image 1 of 2 ASUS Q324UA-BHI7T17 CPU Fan Replacement: step 2, image 2 of 2
    • Carefully remove the backplate using the plastic opening tool.
  3. ASUS Q324UA-BHI7T17 CPU Fan Replacement: step 3, image 1 of 1
    • Locate the battery near the bottom.
  4. ASUS Q324UA-BHI7T17 CPU Fan Replacement: step 4, image 1 of 1
    Tool used on this step:
    Buy
    • Next, lift up the battery connector from the laptop in the upper left side of the battery, using tweezers or spudger.
    • Make sure to complete this step with caution, because if the battery is not unplugged, the motherboard may shock you.
  5. ASUS Q324UA-BHI7T17 CPU Fan Replacement: step 5, image 1 of 2 ASUS Q324UA-BHI7T17 CPU Fan Replacement: step 5, image 2 of 2
    • Remove the six screws holding in the battery with a Phillips #0 screwdriver.
    • Once battery is lifted out and removed, proper dispose of the old battery.
    • Each screw is 0.5 cm in length and 0.5 cm in diameter.
  6. ASUS Q324UA-BHI7T17 CPU Fan Replacement, CPU Fan: step 6, image 1 of 2 ASUS Q324UA-BHI7T17 CPU Fan Replacement, CPU Fan: step 6, image 2 of 2
    • Using a Phillips #0 screwdriver remove the six screws holding the CPU Fan and Heatsink in place.
    • All six screws are 0.4 cm in length and have a 0.5 cm head diameter.
  7. ASUS Q324UA-BHI7T17 CPU Fan Replacement: step 7, image 1 of 2 ASUS Q324UA-BHI7T17 CPU Fan Replacement: step 7, image 2 of 2
    Buy
    • Next, carefully remove the sliding connector that connect the CPU Fan and the laptop together using the tweezers.
  8. ASUS Q324UA-BHI7T17 CPU Fan Replacement: step 8, image 1 of 1
    • Remove the CPU Fan and Heatsink by simply lifting upwards.
Scott Santiago
534 Reputation
5 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 15
All Time: 1,069
