ASUS Q324UA-BHI7T17 Display Assembly Replacement
  1. ASUS Q324UA-BHI7T17 Display Assembly Replacement, Display Assembly: step 1, image 1 of 2 ASUS Q324UA-BHI7T17 Display Assembly Replacement, Display Assembly: step 1, image 2 of 2
    • Remove all ten 5mm crews on the backplate using a Phillips #0 Screwdriver.
    • Remove the back plate by prying from side.
  2. ASUS Q324UA-BHI7T17 Display Assembly Replacement: step 2, image 1 of 1
    • Remove the back plate to access internal components.
  3. ASUS Q324UA-BHI7T17 Display Assembly Replacement: step 3, image 1 of 2 ASUS Q324UA-BHI7T17 Display Assembly Replacement: step 3, image 2 of 2
    Tool used on this step:
    Buy
    • Use a pair of tweezers to disconnect the two black rectangle connections.
  4. ASUS Q324UA-BHI7T17 Display Assembly Replacement: step 4, image 1 of 2 ASUS Q324UA-BHI7T17 Display Assembly Replacement: step 4, image 2 of 2
    • Remove two 6 mm screws using a Phillips #0 Screwdriver.
  5. ASUS Q324UA-BHI7T17 Display Assembly Replacement: step 5, image 1 of 2 ASUS Q324UA-BHI7T17 Display Assembly Replacement: step 5, image 2 of 2
    • Everything should be disconnected. Separate the display from the laptop.
  6. ASUS Q324UA-BHI7T17 Display Assembly Replacement: step 6, image 1 of 3 ASUS Q324UA-BHI7T17 Display Assembly Replacement: step 6, image 2 of 3 ASUS Q324UA-BHI7T17 Display Assembly Replacement: step 6, image 3 of 3
    • Wedge the Jimmy between screen and plastic cover and pry apart.
  7. ASUS Q324UA-BHI7T17 Display Assembly Replacement: step 7, image 1 of 2 ASUS Q324UA-BHI7T17 Display Assembly Replacement: step 7, image 2 of 2
    • Dislodge the wires connected to screen from between hinge and plastic cover.
    • Pulling the wires out will require substantial force.
  8. ASUS Q324UA-BHI7T17 Display Assembly Replacement: step 8, image 1 of 1
    • Remove the display from the device.
Gabriel survance
343 Reputation
2 Guides authored
IUPUI, Team S2-G2, Harley Spring 2019 Member of IUPUI, Team S2-G2, Harley Spring 2019
IUPUI-HARLEY-S19S2G2
3 Members
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 433
