ASUS Q324UA-BHI7T17 Power & Volume Button PCB Board Replacement
  1. ASUS Q324UA-BHI7T17 Power & Volume Button PCB Board Replacement, Battery: step 1, image 1 of 1
    • Remove all 10 Phillips screws on the backplate.
    • All 10 screws are 0.55 inches and 20 mm in diameter.
  2. ASUS Q324UA-BHI7T17 Power & Volume Button PCB Board Replacement: step 2, image 1 of 2 ASUS Q324UA-BHI7T17 Power & Volume Button PCB Board Replacement: step 2, image 2 of 2
    • Carefully remove the backplate using the plastic opening tool.
  3. ASUS Q324UA-BHI7T17 Power & Volume Button PCB Board Replacement: step 3, image 1 of 1
    • Locate the battery near the bottom.
  4. ASUS Q324UA-BHI7T17 Power & Volume Button PCB Board Replacement: step 4, image 1 of 1
    Tool used on this step:
    Buy
    • Next, lift up the battery connector from the laptop in the upper left side of the battery, using tweezers or spudger.
    • Make sure to complete this step with caution, because if the battery is not unplugged, the motherboard may shock you.
  5. ASUS Q324UA-BHI7T17 Power & Volume Button PCB Board Replacement: step 5, image 1 of 2 ASUS Q324UA-BHI7T17 Power & Volume Button PCB Board Replacement: step 5, image 2 of 2
    • Remove the six screws holding in the battery with a Phillips #0 screwdriver.
    • Once battery is lifted out and removed, proper dispose of the old battery.
    • Each screw is 0.5 cm in length and 0.5 cm in diameter.
  6. ASUS Q324UA-BHI7T17 Power & Volume Button PCB Board Replacement, Power & Volume Button PCB Board: step 6, image 1 of 1
    • Remove the screw holding the Power chip in place and remove it using a Phillips head #0 screw driver.
    • Screw length is 0.5 cm in length and 0.5 cm in diameter
  7. ASUS Q324UA-BHI7T17 Power & Volume Button PCB Board Replacement: step 7, image 1 of 3 ASUS Q324UA-BHI7T17 Power & Volume Button PCB Board Replacement: step 7, image 2 of 3 ASUS Q324UA-BHI7T17 Power & Volume Button PCB Board Replacement: step 7, image 3 of 3
    • Locate the ribbon connector connecting the power chip to the mother board.
    • Simply lift up the black component and the ribbon connector should be released, then the power chip should pop out easily.
    • Discard of the old power chip properly.
Scott Santiago
534 Reputation
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 15
All Time: 665
