ASUS Q324UA-BHI7T17 Track Pad Replacement
  1. ASUS Q324UA-BHI7T17 Track Pad Replacement, Track Pad: step 1, image 1 of 2 ASUS Q324UA-BHI7T17 Track Pad Replacement, Track Pad: step 1, image 2 of 2
    • Remove all ten 5mm screws from the backplate using a Phillips #0 Screwdriver.
  2. ASUS Q324UA-BHI7T17 Track Pad Replacement: step 2, image 1 of 1
    • Carefully remove the backplate using the plastic opening tool.
  3. ASUS Q324UA-BHI7T17 Track Pad Replacement: step 3, image 1 of 1
    • Lift up the back plate and slide it to the back of the computer to remove.
  4. ASUS Q324UA-BHI7T17 Track Pad Replacement: step 4, image 1 of 3 ASUS Q324UA-BHI7T17 Track Pad Replacement: step 4, image 2 of 3 ASUS Q324UA-BHI7T17 Track Pad Replacement: step 4, image 3 of 3
    Tool used on this step:
    Buy
    • Disconnect the battery from the laptop in the upper left side of the battery, using tweezers.
  5. ASUS Q324UA-BHI7T17 Track Pad Replacement: step 5, image 1 of 1
    • Remove the six 5 mm screws holding the battery using a Phillips #0 screwdriver.
  6. ASUS Q324UA-BHI7T17 Track Pad Replacement: step 6, image 1 of 1
    • Carefully remove the battery using the plastic opening tool.
  7. ASUS Q324UA-BHI7T17 Track Pad Replacement: step 7, image 1 of 3 ASUS Q324UA-BHI7T17 Track Pad Replacement: step 7, image 2 of 3 ASUS Q324UA-BHI7T17 Track Pad Replacement: step 7, image 3 of 3
    • Disconnect the trackpad from the motherboard using tweezers.
    • The white tab flips up.
  8. ASUS Q324UA-BHI7T17 Track Pad Replacement: step 8, image 1 of 2 ASUS Q324UA-BHI7T17 Track Pad Replacement: step 8, image 2 of 2
    • Remove the two 5mm screws holding in the trackpad using a Phillips #0 screwdriver.
  9. ASUS Q324UA-BHI7T17 Track Pad Replacement: step 9, image 1 of 2 ASUS Q324UA-BHI7T17 Track Pad Replacement: step 9, image 2 of 2
    • Remove adhesive tape tethering the trackpad to the motherboard with tweezers.
  10. ASUS Q324UA-BHI7T17 Track Pad Replacement: step 10, image 1 of 3 ASUS Q324UA-BHI7T17 Track Pad Replacement: step 10, image 2 of 3 ASUS Q324UA-BHI7T17 Track Pad Replacement: step 10, image 3 of 3
    • Carefully remove the trackpad using the plastic opening tool.
    • Lift up and side track toward the back of the computer to remove.
Gabriel survance
343 Reputation
2 Guides authored
IUPUI, Team S2-G2, Harley Spring 2019 Member of IUPUI, Team S2-G2, Harley Spring 2019
IUPUI-HARLEY-S19S2G2
3 Members
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 188
