ASUS Q400A-BHI7N03 Battery Replacement
  1. ASUS Q400A-BHI7N03 Battery Replacement, Battery: step 1, image 1 of 1
    • Turn off the laptop.
    • Disconnect the charging cable from the laptop.
    • Failure to unplug the cable could result in electric shock.
    • Flip the laptop over so that it is upside down.
    • The slightly raised area is the battery.
    • Orient the laptop so that the battery is away from you.
  2. ASUS Q400A-BHI7N03 Battery Replacement: step 2, image 1 of 1
    • In the top right corner, push the tab to the right to the unlocked position.
  3. ASUS Q400A-BHI7N03 Battery Replacement: step 3, image 1 of 2 ASUS Q400A-BHI7N03 Battery Replacement: step 3, image 2 of 2
    • Find the tab in the top left corner. With one finger, pull the tab to the left to the unlocked position.
    • While holding this tab in the unlocked position, gently pull the battery away from you.
To reinsert your battery, follow these instructions in reverse order. Remember to re-lock the tab in step 2.
Matthew Gold
401 Reputation
4 Guides authored
UC Davis, Team 1-4, Rodger Winter 2017 Member of UC Davis, Team 1-4, Rodger Winter 2017
UCD-RODGER-W17S1G4
5 Members
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 15
All Time: 694
