ASUS Q536F Display Assembly Replacement
  1. ASUS Q536F Display Assembly Replacement, Back Panel: step 1, image 1 of 2 ASUS Q536F Display Assembly Replacement, Back Panel: step 1, image 2 of 2
    • Remove ten 2 mm screws using a Phillips #0 screwdriver.
    • Remove the screw in the center using a T4 Torx screwdriver.
    • Use an iFixit opening tool to pry open the back panel.
    • It's normal to hear some cracking, but proceed with caution.
  2. ASUS Q536F Display Assembly Replacement, Display Assembly: step 2, image 1 of 1
    • Remove the six 2 mm screws from the hinges using a Phillips #0 screwdriver.
  3. ASUS Q536F Display Assembly Replacement: step 3, image 1 of 3 ASUS Q536F Display Assembly Replacement: step 3, image 2 of 3 ASUS Q536F Display Assembly Replacement: step 3, image 3 of 3
    • Using your fingers, unplug the two power cables connecting the display to the motherboard.
    • Remove the display assembly from the laptop.
Kristen Gismondi
84,908 Reputation
215 Guides authored
iFixit Member of iFixit
Staff
141 Members
17,908 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 6
All Time: 29
