ASUS Q536F Fan Replacement
  1. ASUS Q536F Fan Replacement, Back Panel: step 1, image 1 of 2 ASUS Q536F Fan Replacement, Back Panel: step 1, image 2 of 2
    • Remove ten 2 mm screws using a Phillips #0 screwdriver.
    • Remove the screw in the center using a T4 Torx screwdriver.
    • Use an iFixit opening tool to pry open the back panel.
    • It's normal to hear some cracking, but proceed with caution.
  2. ASUS Q536F Fan Replacement, Fan: step 2, image 1 of 2 ASUS Q536F Fan Replacement, Fan: step 2, image 2 of 2
    • Use a Phillips #0 screwdriver to remove the six 2 mm fan screws.
    • Use a Phillips #0 screwdriver to remove the five 2 mm heatsink screws.
    • Warped Screw
    • Heatsink shown has warped screw, so unable to remove
  3. ASUS Q536F Fan Replacement: step 3, image 1 of 1
    Tool used on this step:
    Buy
    • Disconnect white and black antennae cables.
    • Using tweezers for this would be helpful.
  4. ASUS Q536F Fan Replacement: step 4, image 1 of 2 ASUS Q536F Fan Replacement: step 4, image 2 of 2
    • Disconnect fan cables pulling outwards as shown.
  5. ASUS Q536F Fan Replacement: step 5, image 1 of 3 ASUS Q536F Fan Replacement: step 5, image 2 of 3 ASUS Q536F Fan Replacement: step 5, image 3 of 3
    • Carefully lift heatsink upward using a Ifixit opening tool or Fingers pull fan out from under the heat sink.
    • The fan can be removed without removing the heatsink, although it may be easier to remove.
Adra Ledward
557 Reputation
5 Guides authored
Gateway, Team 88-8, Gonzalez Fall 2023 Member of Gateway, Team 88-8, Gonzalez Fall 2023
GCC-GONZALEZ-F23S88G8
5 Members
6 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 7
All Time: 308
