ASUS Q536F SSD Replacement
  1. ASUS Q536F SSD Replacement, Back Panel: step 1, image 1 of 2 ASUS Q536F SSD Replacement, Back Panel: step 1, image 2 of 2
    • Remove ten 2 mm screws using a Phillips #0 screwdriver.
    • Remove the screw in the center using a T4 Torx screwdriver.
    • Use an iFixit opening tool to pry open the back panel.
    • It's normal to hear some cracking, but proceed with caution.
  2. ASUS Q536F SSD Replacement, SSD: step 2, image 1 of 1
    • Remove the single 2 mm screw from the SSD with a Phillips #0 screwdriver.
  3. ASUS Q536F SSD Replacement: step 3, image 1 of 1
    • Pull the SSD out of its slot.
To reassemble your device, Follow these instructions in reverse order.
Adra Ledward
557 Reputation
5 Guides authored
Gateway, Team 88-8, Gonzalez Fall 2023 Member of Gateway, Team 88-8, Gonzalez Fall 2023
GCC-GONZALEZ-F23S88G8
5 Members
6 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 9
All Time: 328
