ASUS R554L Battery Replacement
  1. ASUS R554L Battery Replacement, Battery: step 1, image 1 of 1
    • Flip the laptop so the bottom is facing upward.
    • Remove ten screws using a Phillips #0 screwdriver.
  2. ASUS R554L Battery Replacement: step 2, image 1 of 3 ASUS R554L Battery Replacement: step 2, image 2 of 3 ASUS R554L Battery Replacement: step 2, image 3 of 3
    • Using your fingertips, carefully pull the backplate in an upright direction.
    • Continue along the edges until the backplate is fully removed.
    • It's normal to hear cracking while pulling up on the plate.
  3. ASUS R554L Battery Replacement: step 3, image 1 of 3 ASUS R554L Battery Replacement: step 3, image 2 of 3 ASUS R554L Battery Replacement: step 3, image 3 of 3
    • Remove the four screws from the battery using a Phillips #0 screwdriver.
    • Pull up on the cable connected to the motherboard to remove.
    • Remove the battery from the bay.
  4. ASUS R554L Battery Replacement: step 4, image 1 of 3 ASUS R554L Battery Replacement: step 4, image 2 of 3 ASUS R554L Battery Replacement: step 4, image 3 of 3
    • Place the new battery in the bay.
    • Install the battery cable to the motherboard, applying pressure in a downward direction.
    • Screws the screws back in using a Phillips #0 screwdriver.
  5. ASUS R554L Battery Replacement: step 5, image 1 of 3 ASUS R554L Battery Replacement: step 5, image 2 of 3 ASUS R554L Battery Replacement: step 5, image 3 of 3
    • Align the backplate.
    • Starting with the upper right corner, apply pressure in a downward angle.
    • Repeat the process around the backplate until it's fully secure.
  6. ASUS R554L Battery Replacement: step 6, image 1 of 2 ASUS R554L Battery Replacement: step 6, image 2 of 2
    • Screw the backplate screws back in using a Phillips #0 screwdriver.
Once the new battery is installed, leave the charger connected to the laptop over night to ensure the battery is holding a charge
3 other people completed this guide.
Joshua Chavez
214 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 24
Past 30 Days: 116
All Time: 7,262
