Video Overview
This teardown is not a repair guide. To repair your Asus ROG Ally, use our service manual.
  1. ASUS ROG Ally Chip ID, Main Board Side 1: step 1, image 1 of 2 ASUS ROG Ally Chip ID, Main Board Side 1: step 1, image 2 of 2
    • AMD 100-000001278 3.3 GHz octa-core Ryzen Z1 Extreme applications processor
    • Samsung K3LKBKB0BM-MGCP 4 GB LPDDR5 SDRAM memory
    • Renesas ISL9241HRTZ Li-ion SMBus buck-boost battery charger
    • onsemi CAT24C512 64 KB serial EEPROM memory
    • Realtek ALC3288 audio codec
    • Cirrus Logic CS35L51X audio amplifier
    • Monolithic Power Systems MP2845A multi-phase controller
  2. ASUS ROG Ally Chip ID: step 2, image 1 of 1
    • Monolithic Power Systems MP86949 45 A power stage
    • Texas Instruments TPS51285ARUK dual synchronous step-down controller w/ LDOs
    • Silergy SY8388ARHC 8 A synchronous step-down regulator
    • Silergy synchronous step-down converter (likely)
    • Monolithic Power Systems DC-DC converter (likely)
    • Torex Semiconductor XC6223K3019R-G 300 mA / 3.00 V LDO regulator
    • Texas Instruments TMUX154ERSWR 2-ch. SPDT analog switch
  3. ASUS ROG Ally Chip ID: step 3, image 1 of 1
    • Kinetic Technologies KTS1690AEGAA-TA USB VBUS load switch
    • Kinetic Technologies KTS1681AEUZ-TR 4 A over-voltage protection
    • Kinetic Technologies Dual Output Load Switch with OVP ?
  4. ASUS ROG Ally Chip ID, Main Board Side 1 - Sensors: step 4, image 1 of 1
    • Bosch Sensortec BMI323 6-axis MEMS accelerometer & gyroscope w/ temperature sensor
    • Likely Texas Instruments temperature sensor
  5. ASUS ROG Ally Chip ID, Main Board Side 2: step 5, image 1 of 2 ASUS ROG Ally Chip ID, Main Board Side 2: step 5, image 2 of 2
    • ITE Tech IT5125VG-192 keyboard & embedded controller
    • ITE Tech IT8856FN USB type-C power delivery controller
    • Genesys Logic GL9755 card reader controller
    • Winbond W74M25JW 32 MB authentication flash memory
    • MEMS Microphone
    • ANPEC Electronics APL6012 15-ch., 8 bit A/D converter
    • Renesas mixed signal array (possibly)
  6. ASUS ROG Ally Chip ID: step 6, image 1 of 1
    • Monolithic Power Systems MP86903C 30 A power stage
    • Infineon IR3883MTRPBF 3 A synchronous DC-DC buck regulator
    • Global Mixed-mode Technology G9661M 3 A / Adj. LDO regulator (likely)
    • Texas Instruments TPS22975DSG 6 A load switch
    • uPI Semi uP9030Q power distribution switch (likely)
    • Texas Instruments TS5A3166DCKR 1-ch. SPST analog switch
    • Texas Instruments SN74LVC1G08 single 2-input AND gate
  7. ASUS ROG Ally Chip ID: step 7, image 1 of 1
  8. ASUS ROG Ally Chip ID, Main Board Side 2 - Sensors: step 8, image 1 of 1
  9. ASUS ROG Ally Chip ID, Joystick Board Side 1: step 9, image 1 of 2 ASUS ROG Ally Chip ID, Joystick Board Side 1: step 9, image 2 of 2
    • Likely ITE Tech IT8237FN248A embedded controller
    • Likely ITE Tech IT8237FN120A embedded controller
    • SG Micro SGM5200 16-ch., 12 bit, 1 MSPS A/D converter
    • SG Micro SGM4040B-2.5 2.5 V voltage reference
    • Possibly Awinic AW86223 haptic driver
6 Comments
Any identification for Wi-Fi and Bluetooth? I don't see anything mentioning what it has.
Parker Reed - Reply
The board in the teardown video (I suspect this same board) has soldered on module with a MediaTek MT7922A12L.
Alisha C -
My Ally came with MediaTek MT7922 (RZ616). Since it has apparent issues with keeping a connection (not caused by the signal!) - I ordered an Intel AX210 to replace it, only to find out that it's apparently soldered and can't be replaced. This should have been mentioned by ifixit - definitely a bad decision! same for the soldered 16GB RAM. Another bad decision. Now I don't know what to do with the Ally. Unreliable Wifi is no option, so maybe return it..
lucker#1 - Reply
What is the function of the empty cable port above the QR code?
李龙啸 - Reply
When I wanted to update the BIOS, my console stopped turning on so now it is necessary to reprogram this BIOS but I can't find the file on the web, could you help me with a copy of your BIOS, I would be very grateful. To make a copy of the BIOS you could use the CH341 programmer
kevin mosquera - Reply
Past 24 Hours: 10
Past 7 Days: 85
Past 30 Days: 498
All Time: 11,907
