ASUS ROG G750JW-RS72-CB Hard Drive Replacement
  1. ASUS ROG G750JW-RS72-CB Hard Drive Replacement, Battery: step 1, image 1 of 1
    • Make sure you completely power down the computer before beginning this process.
    • With your finger, push this slide to the right. The battery should pop out of place.
  2. ASUS ROG G750JW-RS72-CB Hard Drive Replacement: step 2, image 1 of 1
    • Pull the battery out of its place gently.
  3. ASUS ROG G750JW-RS72-CB Hard Drive Replacement, Hard Drive: step 3, image 1 of 1
    • Lift up the flap using a plastic opening tool.
    • Hold the flap back with your finger.
  4. ASUS ROG G750JW-RS72-CB Hard Drive Replacement: step 4, image 1 of 1
    • Unscrew the 5.2mm screw underneath the flap.
  5. ASUS ROG G750JW-RS72-CB Hard Drive Replacement: step 5, image 1 of 2 ASUS ROG G750JW-RS72-CB Hard Drive Replacement: step 5, image 2 of 2
    • Once the screw is out, pull on the plastic tab to pull off the plastic cover.
  6. ASUS ROG G750JW-RS72-CB Hard Drive Replacement: step 6, image 1 of 3 ASUS ROG G750JW-RS72-CB Hard Drive Replacement: step 6, image 2 of 3 ASUS ROG G750JW-RS72-CB Hard Drive Replacement: step 6, image 3 of 3
    • Unscrew the 5.2mm screws holding the hard drive in place.
    • Gently pull the rubber hard drive mount to the side.
    • Pull the drive out.
Joseph Rockwell
243 Reputation
2 Guides authored
Cal Poly, Team S11-G5, Banghart Winter 2018 Member of Cal Poly, Team S11-G5, Banghart Winter 2018
CPSU-BANGHART-W18S11G5
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 7
All Time: 770
