ASUS ROG Strix GL503VD-DB71 Battery Replacement
  1. ASUS ROG Strix GL503VD-DB71 Battery Replacement, Battery: step 1, image 1 of 2 ASUS ROG Strix GL503VD-DB71 Battery Replacement, Battery: step 1, image 2 of 2
    • Start with flipping the laptop over so that the bottom side is facing up.
  2. ASUS ROG Strix GL503VD-DB71 Battery Replacement: step 2, image 1 of 3 ASUS ROG Strix GL503VD-DB71 Battery Replacement: step 2, image 2 of 3 ASUS ROG Strix GL503VD-DB71 Battery Replacement: step 2, image 3 of 3
    • Remove the screw for the small panel with a Phillips #1 screwdriver.
    • Use your plastic opening tool to lift up the cover to remove it.
    • Remove the screw beneath the service cover with a Phillips #1 screwdriver.
  3. ASUS ROG Strix GL503VD-DB71 Battery Replacement: step 3, image 1 of 3 ASUS ROG Strix GL503VD-DB71 Battery Replacement: step 3, image 2 of 3 ASUS ROG Strix GL503VD-DB71 Battery Replacement: step 3, image 3 of 3
    • Remove the 9 screws around the perimeter of the back case with a Phillips #1 screwdriver.
    • Use a plastic opening tool to pry the back cover off of the device.
    • Remove the back cover exposing the battery.
  4. ASUS ROG Strix GL503VD-DB71 Battery Replacement: step 4, image 1 of 3 ASUS ROG Strix GL503VD-DB71 Battery Replacement: step 4, image 2 of 3 ASUS ROG Strix GL503VD-DB71 Battery Replacement: step 4, image 3 of 3
    • Remove the single screw securing the battery with a Phillips #1 screwdriver.
    • Gently pull the battery cable from its connector on the motherboard.
    • Lift up on the battery to remove it.
2 other people completed this guide.
0 Comments
Past 24 Hours: 3
Past 7 Days: 10
Past 30 Days: 73
All Time: 5,275
