ASUS TUF Gaming FX505DY Back Case Replacement
  1. ASUS TUF Gaming FX505DY Back Case Replacement, Back Case: step 1, image 1 of 1
    • Turn off the laptop.
    • Disconnect the charging cable.
    • Failure to disconnect the charging cable and power down the computer could result in personal or property damage.
    • Flip the laptop so the back is facing up.
  2. ASUS TUF Gaming FX505DY Back Case Replacement: step 2, image 1 of 2 ASUS TUF Gaming FX505DY Back Case Replacement: step 2, image 2 of 2
    • Use a Phillips #1 screwdriver to remove the five 6 mm screws that secure the back panel.
    • Use the same screwdriver to remove the six 13 mm screws securing the back panel.
  3. ASUS TUF Gaming FX505DY Back Case Replacement: step 3, image 1 of 2 ASUS TUF Gaming FX505DY Back Case Replacement: step 3, image 2 of 2
    • Insert the plastic opening tool at a corner and pry up along the edges, leaving the back side with the hinges for last.
    • Do not insert the opening tool too far into the laptop to avoid damaging internal components.
  4. ASUS TUF Gaming FX505DY Back Case Replacement: step 4, image 1 of 2 ASUS TUF Gaming FX505DY Back Case Replacement: step 4, image 2 of 2
    • Gently lift up the back panel to release any remaining clips on the side with the hinges and remove the panel.
2 other people completed this guide.
Benyamin Claxton
1,010 Reputation
5 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 63
All Time: 1,447
