ASUS TUF Gaming FX505DY Display Assembly Replacement
  1. ASUS TUF Gaming FX505DY Display Assembly Replacement, Back Case: step 1, image 1 of 1
    • Turn off the laptop.
    • Disconnect the charging cable.
    • Failure to disconnect the charging cable and power down the computer could result in personal or property damage.
    • Flip the laptop so the back is facing up.
  2. ASUS TUF Gaming FX505DY Display Assembly Replacement: step 2, image 1 of 2 ASUS TUF Gaming FX505DY Display Assembly Replacement: step 2, image 2 of 2
    • Use a Phillips #1 screwdriver to remove the five 6 mm screws that secure the back panel.
    • Use the same screwdriver to remove the six 13 mm screws securing the back panel.
  3. ASUS TUF Gaming FX505DY Display Assembly Replacement: step 3, image 1 of 2 ASUS TUF Gaming FX505DY Display Assembly Replacement: step 3, image 2 of 2
    • Insert the plastic opening tool at a corner and pry up along the edges, leaving the back side with the hinges for last.
    • Do not insert the opening tool too far into the laptop to avoid damaging internal components.
  4. ASUS TUF Gaming FX505DY Display Assembly Replacement: step 4, image 1 of 2 ASUS TUF Gaming FX505DY Display Assembly Replacement: step 4, image 2 of 2
    • Gently lift up the back panel to release any remaining clips on the side with the hinges and remove the panel.
  5. ASUS TUF Gaming FX505DY Display Assembly Replacement, Solid State Drive: step 5, image 1 of 2 ASUS TUF Gaming FX505DY Display Assembly Replacement, Solid State Drive: step 5, image 2 of 2
    • Remove the two 3 mm screws holding the solid state drive and its foil wrap in place using a Phillips #1 screwdriver.
    • The drive will pop up at an angle.
  6. ASUS TUF Gaming FX505DY Display Assembly Replacement: step 6, image 1 of 3 ASUS TUF Gaming FX505DY Display Assembly Replacement: step 6, image 2 of 3 ASUS TUF Gaming FX505DY Display Assembly Replacement: step 6, image 3 of 3
    • Slide the foil wrap off of the drive.
  7. ASUS TUF Gaming FX505DY Display Assembly Replacement: step 7, image 1 of 2 ASUS TUF Gaming FX505DY Display Assembly Replacement: step 7, image 2 of 2
    • Remove the solid state drive by pulling it at an angle from the motherboard.
  8. ASUS TUF Gaming FX505DY Display Assembly Replacement, Wi-Fi Card: step 8, image 1 of 1
    • Remove the tape covering the Wi-Fi card.
  9. ASUS TUF Gaming FX505DY Display Assembly Replacement: step 9, image 1 of 3 ASUS TUF Gaming FX505DY Display Assembly Replacement: step 9, image 2 of 3 ASUS TUF Gaming FX505DY Display Assembly Replacement: step 9, image 3 of 3
    Tool used on this step:
    Buy
    • Using ESD-safe tweezers, remove the two coaxial antennas by lifting up on the wires near the connectors.
  10. ASUS TUF Gaming FX505DY Display Assembly Replacement: step 10, image 1 of 2 ASUS TUF Gaming FX505DY Display Assembly Replacement: step 10, image 2 of 2
    • Remove the 6 mm screw using a Phillips #1 screwdriver.
  11. ASUS TUF Gaming FX505DY Display Assembly Replacement: step 11, image 1 of 2 ASUS TUF Gaming FX505DY Display Assembly Replacement: step 11, image 2 of 2
    • Remove the Wi-Fi card by pulling it straight away from its slot.
  12. ASUS TUF Gaming FX505DY Display Assembly Replacement, Display Assembly: step 12, image 1 of 3 ASUS TUF Gaming FX505DY Display Assembly Replacement, Display Assembly: step 12, image 2 of 3 ASUS TUF Gaming FX505DY Display Assembly Replacement, Display Assembly: step 12, image 3 of 3
    • Disconnect the white and black wires from the Wi-Fi chip
  13. ASUS TUF Gaming FX505DY Display Assembly Replacement: step 13, image 1 of 3 ASUS TUF Gaming FX505DY Display Assembly Replacement: step 13, image 2 of 3 ASUS TUF Gaming FX505DY Display Assembly Replacement: step 13, image 3 of 3
    • Remove the white and black wires from the black tape.
  14. ASUS TUF Gaming FX505DY Display Assembly Replacement: step 14, image 1 of 3 ASUS TUF Gaming FX505DY Display Assembly Replacement: step 14, image 2 of 3 ASUS TUF Gaming FX505DY Display Assembly Replacement: step 14, image 3 of 3
    • Unhinge and pull the display cable from the mother board.
    • The port should be labeled "LVDS" and located between the cooling fan and the hard drive.
  15. ASUS TUF Gaming FX505DY Display Assembly Replacement: step 15, image 1 of 3 ASUS TUF Gaming FX505DY Display Assembly Replacement: step 15, image 2 of 3 ASUS TUF Gaming FX505DY Display Assembly Replacement: step 15, image 3 of 3
    • Unscrew and lift the hinge.
    • Some hinges may be tough to pull, proceed with caution.
  16. ASUS TUF Gaming FX505DY Display Assembly Replacement: step 16, image 1 of 2 ASUS TUF Gaming FX505DY Display Assembly Replacement: step 16, image 2 of 2
    • Unhinge the other side, and remove the display from the rest of the computer.
Nick Pearcy
313 Reputation
3 Guides authored
IUPUI, Team 2-3, Harley Spring 2023 Member of IUPUI, Team 2-3, Harley Spring 2023
IUPUI-HARLEY-S23S2G3
3 Members
3 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 41
All Time: 444
