ASUS TUF Gaming FX505DY Speakers Replacement
  1. ASUS TUF Gaming FX505DY Speakers Replacement, Back Case: step 1, image 1 of 1
    • Turn off the laptop.
    • Disconnect the charging cable.
    • Failure to disconnect the charging cable and power down the computer could result in personal or property damage.
    • Flip the laptop so the back is facing up.
  2. ASUS TUF Gaming FX505DY Speakers Replacement: step 2, image 1 of 2 ASUS TUF Gaming FX505DY Speakers Replacement: step 2, image 2 of 2
    • Use a Phillips #1 screwdriver to remove the five 6 mm screws that secure the back panel.
    • Use the same screwdriver to remove the six 13 mm screws securing the back panel.
  3. ASUS TUF Gaming FX505DY Speakers Replacement: step 3, image 1 of 2 ASUS TUF Gaming FX505DY Speakers Replacement: step 3, image 2 of 2
    • Insert the plastic opening tool at a corner and pry up along the edges, leaving the back side with the hinges for last.
    • Do not insert the opening tool too far into the laptop to avoid damaging internal components.
  4. ASUS TUF Gaming FX505DY Speakers Replacement: step 4, image 1 of 2 ASUS TUF Gaming FX505DY Speakers Replacement: step 4, image 2 of 2
    • Gently lift up the back panel to release any remaining clips on the side with the hinges and remove the panel.
    Recommend a step here to unplug the battery internally. I discovered that you can short out the display ribbon cable pretty easily if you don't have it perfectly aligned with the connector bracket. It led to one of my pins being fried black and a gross deposit in the connector. Still seems to work though.
    Ben Hart - Reply
  5. ASUS TUF Gaming FX505DY Speakers Replacement, Battery: step 5, image 1 of 3 ASUS TUF Gaming FX505DY Speakers Replacement, Battery: step 5, image 2 of 3 ASUS TUF Gaming FX505DY Speakers Replacement, Battery: step 5, image 3 of 3
    • Using an ESD-safe spudger, disconnect the battery connector by pulling the plug away from its port.
  6. ASUS TUF Gaming FX505DY Speakers Replacement: step 6, image 1 of 2 ASUS TUF Gaming FX505DY Speakers Replacement: step 6, image 2 of 2
    • Remove the 6 mm screw holding the battery in place using a Phillips #1 screwdriver.
    • Avoid cutting, puncturing, or otherwise damaging the battery. Li-ion batteries can combust or explode if damaged.
  7. ASUS TUF Gaming FX505DY Speakers Replacement: step 7, image 1 of 3 ASUS TUF Gaming FX505DY Speakers Replacement: step 7, image 2 of 3 ASUS TUF Gaming FX505DY Speakers Replacement: step 7, image 3 of 3
    • Use a spudger to pry the retaining pin into the closed position to allow the battery frame to be removed.
  8. ASUS TUF Gaming FX505DY Speakers Replacement: step 8, image 1 of 1
    • Lift the battery up out of the computer.
  9. ASUS TUF Gaming FX505DY Speakers Replacement, Speakers: step 9, image 1 of 2 ASUS TUF Gaming FX505DY Speakers Replacement, Speakers: step 9, image 2 of 2
    • Lift the speakers from the pegs holding them down. Use minimal force as to not break the pegs or the speakers.
  10. ASUS TUF Gaming FX505DY Speakers Replacement: step 10, image 1 of 2 ASUS TUF Gaming FX505DY Speakers Replacement: step 10, image 2 of 2
    • Identify the place where the speaker cable connects to the motherboard. The port should be "SPK"
  11. ASUS TUF Gaming FX505DY Speakers Replacement: step 11, image 1 of 2 ASUS TUF Gaming FX505DY Speakers Replacement: step 11, image 2 of 2
    • Pull the cable off the motherboard using a plastic pick or other pointed item and remove the speakers.
Nick Pearcy
313 Reputation
3 Guides authored
IUPUI, Team 2-3, Harley Spring 2023 Member of IUPUI, Team 2-3, Harley Spring 2023
IUPUI-HARLEY-S23S2G3
3 Members
3 Guides authored
One Comment
model for the speaker. I want to buy a replacement , which one should I buy . I cant get original.
albert enstine - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 33
All Time: 776
