ASUS U57A-BBL4 Display Assembly Replacement
  1. ASUS U57A-BBL4 Display Assembly Replacement, Display Assembly: step 1, image 1 of 2 ASUS U57A-BBL4 Display Assembly Replacement, Display Assembly: step 1, image 2 of 2
    • Carefully pry the two rubber covers at the bottom of the screen off with a metal sprudger.
  2. ASUS U57A-BBL4 Display Assembly Replacement: step 2, image 1 of 1
    • Remove the two 1.84 mm Phillips head screws at the bottom of the screen using PH00 screw driver.
  3. ASUS U57A-BBL4 Display Assembly Replacement: step 3, image 1 of 1
    • Starting from one of the corners, use your fingers to pry the bezel from the screen.
    • There is a popping sound when the bezel is loosened from the screen.
  4. ASUS U57A-BBL4 Display Assembly Replacement: step 4, image 1 of 3 ASUS U57A-BBL4 Display Assembly Replacement: step 4, image 2 of 3 ASUS U57A-BBL4 Display Assembly Replacement: step 4, image 3 of 3
    • Remove the top two 2 mm Phillips head screws.
    • Remove the four 2 mm Phillips head screws on the bottom.
    • Remove the eight 2 mm Phillips head screws on the sides of the screen. There are four on each side.
    • There are 14 screws in total: two on the top, four on the bottom, and four on each side. Use PH00 screw-driver for removing all 14 screws.
  5. ASUS U57A-BBL4 Display Assembly Replacement: step 5, image 1 of 2 ASUS U57A-BBL4 Display Assembly Replacement: step 5, image 2 of 2
    • Don't tear off the bottom of the screen or you might damage the connector cable.
    • Carefully lower the screen from the casing with your fingers, making sure to keep the bottom intact and lay it face down on the keyboard.
  6. ASUS U57A-BBL4 Display Assembly Replacement: step 6, image 1 of 2 ASUS U57A-BBL4 Display Assembly Replacement: step 6, image 2 of 2
    • Disconnect the connector cable at the bottom by loosening the adhesive tape and lifting up.
    • Gently slide the cable out of the ridges to free the screen from the casing.
Isabella Bernardi
671 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 10
All Time: 362
