ASUS U57A-BBL4 Keyboard Replacement
  1. ASUS U57A-BBL4 Keyboard Replacement, Remove battery: step 1, image 1 of 1
    • Flip the laptop upside-down, battery side facing you.
    • Move the left latch to the left. You can let go after moving it.
    • Move the right latch to the right, and don't let go.
    • Pull the battery out with your other hand.
  2. ASUS U57A-BBL4 Keyboard Replacement, Remove RAM cover: step 2, image 1 of 1
    • Remove the two Philips screws securing the RAM cover.
  3. ASUS U57A-BBL4 Keyboard Replacement, Separate palmrest from base: step 3, image 1 of 2 ASUS U57A-BBL4 Keyboard Replacement, Separate palmrest from base: step 3, image 2 of 2
    • Remove the eight longer Philips screws securing the palmrest to the base.
    • Remove thet four longer and thicker Philips screws securing the palmrest to the base.
    • Remove the single remaining small Philips screw securing the palmrest to the base.
    • Remove the cover hiding the last remaining, medium-length Philips screw.
    • Use a spudger to separate the palmrest from the base.
  4. ASUS U57A-BBL4 Keyboard Replacement, Remove palmrest cables & palmrest: step 4, image 1 of 2 ASUS U57A-BBL4 Keyboard Replacement, Remove palmrest cables & palmrest: step 4, image 2 of 2
    • Slowly move the palmrest to the right, until you begin to see a ZIF cable. Stop moving the palmrest once you see the cable. Remove the cable.
    • Now, lift the palmrest up slowly, until you see more ZIF cables. Remove both of them.
    • There are no more cables, so you may now take the palmrest away from the laptop.
  5. ASUS U57A-BBL4 Keyboard Replacement, Remove keyboard plate: step 5, image 1 of 1
    • Remove the nine pan-head Philips screws.
    • Remove the five rather annoying small Philips screws.
    • Peel back the metal tape holding the keyboard plate, and also peel back the cable attached to it.
    • Now yank the keyboard plate out. Be sure you didn't miss any screws.
    • You're done disassembling!
Joseph Sctbunio
7,767 Reputation
42 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 662
