ASUS U57A-BBL4 Optical Drive Replacement
  1. ASUS U57A-BBL4 Optical Drive Replacement, Battery: step 1, image 1 of 1
    • Make sure the laptop is completely shut down to avoid data complications.
    • Hold the left lock switch towards the left to the unlock option.
  2. ASUS U57A-BBL4 Optical Drive Replacement: step 2, image 1 of 1
    • Toggle the right lock switch to the unlock option.
  3. ASUS U57A-BBL4 Optical Drive Replacement: step 3, image 1 of 1
    • Gently slide the battery out while still holding the left unlock switch.
  4. ASUS U57A-BBL4 Optical Drive Replacement, Front Panel Assembly: step 4, image 1 of 2 ASUS U57A-BBL4 Optical Drive Replacement, Front Panel Assembly: step 4, image 2 of 2
    • Remove the two 2 mm Phillips head screws on each side on the bottom using PH00 screw driver.
    • Remove the one 2 mm screw underneath the black cover in the middle using the same screw driver.
  5. ASUS U57A-BBL4 Optical Drive Replacement: step 5, image 1 of 1
    • Remove the RAM by lifting up with your fingers and sliding it out towards you.
  6. ASUS U57A-BBL4 Optical Drive Replacement: step 6, image 1 of 1
    • Remove the three 2 mm Phillips head screws on the hard drive using PH00 screw driver.
    • Remove the remaining seven 1.8 mm Phillips head screws using the same screw driver.
  7. ASUS U57A-BBL4 Optical Drive Replacement: step 7, image 1 of 2 ASUS U57A-BBL4 Optical Drive Replacement: step 7, image 2 of 2
    • Remove the hard drive by sliding it to the left and lifting up.
  8. ASUS U57A-BBL4 Optical Drive Replacement: step 8, image 1 of 2 ASUS U57A-BBL4 Optical Drive Replacement: step 8, image 2 of 2
    • Remove the six 2 mm Phillips head screws on the top edge of the laptop using PH00 screw driver.
    • Flip the laptop right-side up and open the screen.
  9. ASUS U57A-BBL4 Optical Drive Replacement: step 9, image 1 of 3 ASUS U57A-BBL4 Optical Drive Replacement: step 9, image 2 of 3 ASUS U57A-BBL4 Optical Drive Replacement: step 9, image 3 of 3
    • Starting in a corner of the keyboard, pry the keyboard from the laptop using a plastic opening tool.
    • Remove the ribbon cable on the bottom of the keyboard by lifting up on the tape and pulling up.
    • The front panel is now loose from the laptop.
  10. ASUS U57A-BBL4 Optical Drive Replacement, Optical Drive: step 10, image 1 of 1
    • Slide the optical drive out. It should easily come out.
Isabella Bernardi
671 Reputation
6 Guides authored
One Comment
On my Asus U57A you only have to remove the one 2mm screw under the plastic cover on the bottom and the optical drive slides right out.  This seems like a considerable amount of overkill to me.
Steve Britten - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 11
All Time: 342
