ASUS UX50V-RX05 Hard Drive Replacement
  1. ASUS UX50V-RX05 Hard Drive Replacement, Keyboard: step 1, image 1 of 3 ASUS UX50V-RX05 Hard Drive Replacement, Keyboard: step 1, image 2 of 3 ASUS UX50V-RX05 Hard Drive Replacement, Keyboard: step 1, image 3 of 3
    • Make sure the device is powered off and the battery is removed before beginning.
    • Use the Plastic Opening tool to pry the five slots up at the top of the keyboard.
  2. ASUS UX50V-RX05 Hard Drive Replacement: step 2, image 1 of 2 ASUS UX50V-RX05 Hard Drive Replacement: step 2, image 2 of 2
    • Lift the keyboard enough to expose the two ribbon connectors (LCD flex cable and flex band).
    • Use the Plastic Opening tool to push open the two black clips on each side of the connecting cords.
    • Remove the cable after pushing out the two black clips.
  3. ASUS UX50V-RX05 Hard Drive Replacement: step 3, image 1 of 2 ASUS UX50V-RX05 Hard Drive Replacement: step 3, image 2 of 2
    • Push out each end of the black clip with a plastic opening tool or nylon spudger to remove the ribbon cable.
    • Remove the cable after pushing out both black clips.
    • Remove the keyboard.
  4. ASUS UX50V-RX05 Hard Drive Replacement, Case Removal: step 4, image 1 of 3 ASUS UX50V-RX05 Hard Drive Replacement, Case Removal: step 4, image 2 of 3 ASUS UX50V-RX05 Hard Drive Replacement, Case Removal: step 4, image 3 of 3
    • Remove the thirteen 5 mm J0 screws from the back of the laptop.
    • With the keyboard removed, use the spudger tool to pry around the edge of the laptop until it is free.
  5. ASUS UX50V-RX05 Hard Drive Replacement: step 5, image 1 of 2 ASUS UX50V-RX05 Hard Drive Replacement: step 5, image 2 of 2
    • Use the spudger tool to unplug the two cords from the body by pushing on the tabs on both sides of the plug.
  6. ASUS UX50V-RX05 Hard Drive Replacement: step 6, image 1 of 3 ASUS UX50V-RX05 Hard Drive Replacement: step 6, image 2 of 3 ASUS UX50V-RX05 Hard Drive Replacement: step 6, image 3 of 3
    • With the previous two cords unplugged and out of the way, you can work on unplugging the black cord.
    • Use your fingers to pull up on the clear tab, or use the spudger tool to push out both sides of the connector.
  7. ASUS UX50V-RX05 Hard Drive Replacement: step 7, image 1 of 1
    • Carefully lift and remove the plastic cover to avoid damaging anything.
  8. ASUS UX50V-RX05 Hard Drive Replacement, Hard Drive: step 8, image 1 of 2 ASUS UX50V-RX05 Hard Drive Replacement, Hard Drive: step 8, image 2 of 2
    • Using the screwdriver with the JO bit, remove the two Phillips 4 mm head size 5 mm long screws from the Hard Drive.
  9. ASUS UX50V-RX05 Hard Drive Replacement: step 9, image 1 of 2 ASUS UX50V-RX05 Hard Drive Replacement: step 9, image 2 of 2
    • Flip the Hard Drive over without lifting.
    • Using your fingers, unplug the cord by pulling it away from the hard drive.
  10. ASUS UX50V-RX05 Hard Drive Replacement: step 10, image 1 of 1
    • Unscrew the four black screws from the Hard Drive and slide it out.
James
663 Reputation
6 Guides authored
USF Tampa, Team 20-2, Remmell Spring 2017 Member of USF Tampa, Team 20-2, Remmell Spring 2017
USFT-REMMELL-S17S20G2
4 Members
6 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 21
All Time: 906
