ASUS UX50V-RX05 Motherboard Replacement
  1. ASUS UX50V-RX05 Motherboard Replacement, Keyboard: step 1, image 1 of 3 ASUS UX50V-RX05 Motherboard Replacement, Keyboard: step 1, image 2 of 3 ASUS UX50V-RX05 Motherboard Replacement, Keyboard: step 1, image 3 of 3
    • Make sure the device is powered off and the battery is removed before beginning.
    • Use the Plastic Opening tool to pry the five slots up at the top of the keyboard.
  2. ASUS UX50V-RX05 Motherboard Replacement: step 2, image 1 of 2 ASUS UX50V-RX05 Motherboard Replacement: step 2, image 2 of 2
    • Lift the keyboard enough to expose the two ribbon connectors (LCD flex cable and flex band).
    • Use the Plastic Opening tool to push open the two black clips on each side of the connecting cords.
    • Remove the cable after pushing out the two black clips.
  3. ASUS UX50V-RX05 Motherboard Replacement: step 3, image 1 of 2 ASUS UX50V-RX05 Motherboard Replacement: step 3, image 2 of 2
    • Push out each end of the black clip with a plastic opening tool or nylon spudger to remove the ribbon cable.
    • Remove the cable after pushing out both black clips.
    • Remove the keyboard.
  4. ASUS UX50V-RX05 Motherboard Replacement, Case Removal: step 4, image 1 of 3 ASUS UX50V-RX05 Motherboard Replacement, Case Removal: step 4, image 2 of 3 ASUS UX50V-RX05 Motherboard Replacement, Case Removal: step 4, image 3 of 3
    • Remove the thirteen 5 mm J0 screws from the back of the laptop.
    • With the keyboard removed, use the spudger tool to pry around the edge of the laptop until it is free.
  5. ASUS UX50V-RX05 Motherboard Replacement: step 5, image 1 of 2 ASUS UX50V-RX05 Motherboard Replacement: step 5, image 2 of 2
    • Use the spudger tool to unplug the two cords from the body by pushing on the tabs on both sides of the plug.
  6. ASUS UX50V-RX05 Motherboard Replacement: step 6, image 1 of 3 ASUS UX50V-RX05 Motherboard Replacement: step 6, image 2 of 3 ASUS UX50V-RX05 Motherboard Replacement: step 6, image 3 of 3
    • With the previous two cords unplugged and out of the way, you can work on unplugging the black cord.
    • Use your fingers to pull up on the clear tab, or use the spudger tool to push out both sides of the connector.
  7. ASUS UX50V-RX05 Motherboard Replacement: step 7, image 1 of 1
    • Carefully lift and remove the plastic cover to avoid damaging anything.
  8. ASUS UX50V-RX05 Motherboard Replacement, Optical Drive: step 8, image 1 of 2 ASUS UX50V-RX05 Motherboard Replacement, Optical Drive: step 8, image 2 of 2
    • Remove the four 5 mm J0 screws surrounding the Optical Drive.
    • Remove the optical drive by pulling it out and away from the connector.
  9. ASUS UX50V-RX05 Motherboard Replacement, Motherboard: step 9, image 1 of 3 ASUS UX50V-RX05 Motherboard Replacement, Motherboard: step 9, image 2 of 3 ASUS UX50V-RX05 Motherboard Replacement, Motherboard: step 9, image 3 of 3
    • Use the Plastic Opening Tool to unplug the blue cord on the Motherboard.
  10. ASUS UX50V-RX05 Motherboard Replacement: step 10, image 1 of 2 ASUS UX50V-RX05 Motherboard Replacement: step 10, image 2 of 2
    • Remove the five 4 mm Phillips head 5 mm long screws that have white arrows pointing to them with the screwdriver.
  11. ASUS UX50V-RX05 Motherboard Replacement: step 11, image 1 of 3 ASUS UX50V-RX05 Motherboard Replacement: step 11, image 2 of 3 ASUS UX50V-RX05 Motherboard Replacement: step 11, image 3 of 3
    • Lift the Motherboard with your fingers by reaching underneath the Motherboard and prying.
  12. ASUS UX50V-RX05 Motherboard Replacement: step 12, image 1 of 3 ASUS UX50V-RX05 Motherboard Replacement: step 12, image 2 of 3 ASUS UX50V-RX05 Motherboard Replacement: step 12, image 3 of 3
    • Remove the two 4 mm Phillips head 5 mm long screws from the fan using the screwdriver.
    • Using the Spudger, carefully remove the white connector and lift the fan out of the casing.
  13. ASUS UX50V-RX05 Motherboard Replacement: step 13, image 1 of 3 ASUS UX50V-RX05 Motherboard Replacement: step 13, image 2 of 3 ASUS UX50V-RX05 Motherboard Replacement: step 13, image 3 of 3
    • Slowly lift the motherboard up towards you being careful as to not rip any cords out of the bottom.
    • Using the Spudger, remove the connector towards the bottom of the motherboard.
    • Remove the motherboard from the casing.
2 other people completed this guide.
James
663 Reputation
6 Guides authored
USF Tampa, Team 20-2, Remmell Spring 2017 Member of USF Tampa, Team 20-2, Remmell Spring 2017
USFT-REMMELL-S17S20G2
4 Members
6 Guides authored
1 Guide Comment
From your knowledge is that mother board from the asus ux50v upgrade-able? is the processor integrated into the board?
A Snow - Reply
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 17
All Time: 723
