ASUS VivoBook S300CA-BBI5T01 Battery Replacement
  1. ASUS VivoBook S300CA-BBI5T01 Battery Replacement, Battery: step 1, image 1 of 1
    • Place the laptop upside down so that the bottom panel is facing upwards.
  2. ASUS VivoBook S300CA-BBI5T01 Battery Replacement: step 2, image 1 of 1
    • Unscrew the following 10 screws
    • Eight 5 mm Phillips head screws
    • Two 10 mm Phillips head screws
  3. ASUS VivoBook S300CA-BBI5T01 Battery Replacement: step 3, image 1 of 1
    • Carefully peel the panel off of the bottom of the laptop.
  4. ASUS VivoBook S300CA-BBI5T01 Battery Replacement: step 4, image 1 of 1
    • Remove the 7 screws holding the battery in place.
    • Six 3 mm Phillips head screws
    • One 5 mm Phillips head screw
  5. ASUS VivoBook S300CA-BBI5T01 Battery Replacement: step 5, image 1 of 1
    • Disconnect the one flat topped wire connector by carefully using a plastic opening tool to pry up both sides and then lifting the connector from its socket.
  6. ASUS VivoBook S300CA-BBI5T01 Battery Replacement: step 6, image 1 of 1
    • Slide out the battery.
Keith Rachels
595 Reputation
5 Guides authored
One Comment
Make the Save ESD ?
Konrad Aubreville - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 12
All Time: 3,679
