ASUS VivoBook S300CA-BBI5T01 Wi-Fi Card Replacement
  1. ASUS VivoBook S300CA-BBI5T01 Wi-Fi Card Replacement, Wi-Fi Card: step 1, image 1 of 1
    • Place the laptop upside down so that the bottom panel is facing upwards.
  2. ASUS VivoBook S300CA-BBI5T01 Wi-Fi Card Replacement: step 2, image 1 of 1
    • Unscrew the following 10 screws
    • Eight 5 mm Phillips head screws
    • Two 10 mm Phillips head screws
  3. ASUS VivoBook S300CA-BBI5T01 Wi-Fi Card Replacement: step 3, image 1 of 1
    • Carefully peel the panel off of the bottom of the laptop.
  4. ASUS VivoBook S300CA-BBI5T01 Wi-Fi Card Replacement: step 4, image 1 of 1
    • Remove the one 3 mm Phillips head screw holding the Wi-Fi card in place.
  5. ASUS VivoBook S300CA-BBI5T01 Wi-Fi Card Replacement: step 5, image 1 of 1
    • Carefully slide the card out of its connection port by pulling it outward.
  6. ASUS VivoBook S300CA-BBI5T01 Wi-Fi Card Replacement: step 6, image 1 of 1
    • Remove the black and white antenna cable connector wires by carefully pulling upwards on them.
    • Note that the black wire connects to "Main" and the white wire connects to "Aux".
Keith Rachels
595 Reputation
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 10
All Time: 527
