ASUS VivoBook S400C Display Assembly Replacement
  1. ASUS VivoBook S400C Display Assembly Replacement, Remove the Bottom Cover: step 1, image 1 of 1
    • Flip the device over and remove the ten 5.7 mm screws with a Phillips #0 screwdriver.
  2. ASUS VivoBook S400C Display Assembly Replacement: step 2, image 1 of 2 ASUS VivoBook S400C Display Assembly Replacement: step 2, image 2 of 2
    • Use a spudger or your fingers to go around and lift the edges and release the back panel.
  3. ASUS VivoBook S400C Display Assembly Replacement, Disconnect the Battery: step 3, image 1 of 1
    • Using a spudger, lift up the plug connecting the battery to the motherboard.
  4. ASUS VivoBook S400C Display Assembly Replacement, Heat Shield: step 4, image 1 of 2 ASUS VivoBook S400C Display Assembly Replacement, Heat Shield: step 4, image 2 of 2
    • Remove the black shield covering the display connector and the heat sink.
    • You may need to use double-sided adhesive tape to resecure the shield.
  5. ASUS VivoBook S400C Display Assembly Replacement, Display Assembly: step 5, image 1 of 1
    • Remove the black tape securing the keyboard ribbon cable to the display connector.
    • Fold the ribbon cable the opposite way, resecuring it to the hard drive to keep it out of the way.
  6. ASUS VivoBook S400C Display Assembly Replacement: step 6, image 1 of 2 ASUS VivoBook S400C Display Assembly Replacement: step 6, image 2 of 2
    • Peel off the clear tape from the motherboard display connector.
  7. ASUS VivoBook S400C Display Assembly Replacement: step 7, image 1 of 2 ASUS VivoBook S400C Display Assembly Replacement: step 7, image 2 of 2
    • Position spudgers on the white tabs on either side of the connector and push evenly to unplug the display.
  8. ASUS VivoBook S400C Display Assembly Replacement: step 8, image 1 of 3 ASUS VivoBook S400C Display Assembly Replacement: step 8, image 2 of 3 ASUS VivoBook S400C Display Assembly Replacement: step 8, image 3 of 3
    • Peel off the three pieces of black tape securing the display cable to the motherboard.
    • Deroute the cable from the channel it sits in.
    • Move the cable to the side, out of the way.
  9. ASUS VivoBook S400C Display Assembly Replacement: step 9, image 1 of 3 ASUS VivoBook S400C Display Assembly Replacement: step 9, image 2 of 3 ASUS VivoBook S400C Display Assembly Replacement: step 9, image 3 of 3
    • Use a spudger to release the cables from the wifi card.
  10. ASUS VivoBook S400C Display Assembly Replacement: step 10, image 1 of 3 ASUS VivoBook S400C Display Assembly Replacement: step 10, image 2 of 3 ASUS VivoBook S400C Display Assembly Replacement: step 10, image 3 of 3
    • Lift the tapes securing the wires to the motherboard.
    • Move the wires to the side out of the way.
  11. ASUS VivoBook S400C Display Assembly Replacement, Disconnect the Hinges: step 11, image 1 of 2 ASUS VivoBook S400C Display Assembly Replacement, Disconnect the Hinges: step 11, image 2 of 2
    • Remove the two screws securing the hinge on the left.
    • Pry the hinge up by hand to a 90 degree angle.
  12. ASUS VivoBook S400C Display Assembly Replacement: step 12, image 1 of 2 ASUS VivoBook S400C Display Assembly Replacement: step 12, image 2 of 2
    • Remove the two screws securing the hinge on the right.
  13. ASUS VivoBook S400C Display Assembly Replacement, Remove the Display: step 13, image 1 of 3 ASUS VivoBook S400C Display Assembly Replacement, Remove the Display: step 13, image 2 of 3 ASUS VivoBook S400C Display Assembly Replacement, Remove the Display: step 13, image 3 of 3
    • Lift the base of the laptop from the front.
    • Raise it to a 90 degree angle.
    • Slide it forward slightly to clear the hinges.
    • The display is now free.
Jerry Wheeler
60,257 Reputation
69 Guides authored
Oregonians Member of Oregonians
Community
8 Members
181 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 9
All Time: 260
