ASUS VivoBook S400C I/O Board Replacement
  1. ASUS VivoBook S400C I/O Board Replacement, Remove the Bottom Cover: step 1, image 1 of 1
    • Flip the device over and remove the ten 5.7 mm screws with a Phillips #0 screwdriver.
  2. ASUS VivoBook S400C I/O Board Replacement: step 2, image 1 of 2 ASUS VivoBook S400C I/O Board Replacement: step 2, image 2 of 2
    • Use a spudger or your fingers to go around and lift the edges and release the back panel.
  3. ASUS VivoBook S400C I/O Board Replacement, Disconnect the Battery: step 3, image 1 of 1
    • Using a spudger, lift up the plug connecting the battery to the motherboard.
  4. ASUS VivoBook S400C I/O Board Replacement, I/O Board: step 4, image 1 of 3 ASUS VivoBook S400C I/O Board Replacement, I/O Board: step 4, image 2 of 3 ASUS VivoBook S400C I/O Board Replacement, I/O Board: step 4, image 3 of 3
    • Flip up the retaining latch on the I/O board ribbon cable.
  5. ASUS VivoBook S400C I/O Board Replacement: step 5, image 1 of 2 ASUS VivoBook S400C I/O Board Replacement: step 5, image 2 of 2
    • Pull the cable straight out of the connector by the blue tab.
  6. ASUS VivoBook S400C I/O Board Replacement: step 6, image 1 of 2 ASUS VivoBook S400C I/O Board Replacement: step 6, image 2 of 2
    • Remove the two screws securing the left hinge to the I/O board.
    • Pry the hinge up by hand to a 90 degree angle.
  7. ASUS VivoBook S400C I/O Board Replacement: step 7, image 1 of 1
    • Remove the retaining screw.
  8. ASUS VivoBook S400C I/O Board Replacement: step 8, image 1 of 1
    • Lift the board on the ribbon cable side far enough to clear the guide pin(s) then pull it back away from the side of the case.
Jerry Wheeler
60,257 Reputation
69 Guides authored
Oregonians Member of Oregonians
Community
8 Members
181 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 143
