ASUS VivoBook S400C LED Board Replacement
  1. ASUS VivoBook S400C LED Board Replacement, Remove the Bottom Cover: step 1, image 1 of 1
    • Flip the device over and remove the ten 5.7 mm screws with a Phillips #0 screwdriver.
  2. ASUS VivoBook S400C LED Board Replacement: step 2, image 1 of 2 ASUS VivoBook S400C LED Board Replacement: step 2, image 2 of 2
    • Use a spudger or your fingers to go around and lift the edges and release the back panel.
  3. ASUS VivoBook S400C LED Board Replacement, Disconnect the Battery: step 3, image 1 of 1
    • Using a spudger, lift up the plug connecting the battery to the motherboard.
  4. ASUS VivoBook S400C LED Board Replacement, LED Board: step 4, image 1 of 3 ASUS VivoBook S400C LED Board Replacement, LED Board: step 4, image 2 of 3 ASUS VivoBook S400C LED Board Replacement, LED Board: step 4, image 3 of 3
    • Disconnect the ribbon cable connecting the LED daughterboard and the motherboard by lifting the white tab on the LED side of the cable.
  5. ASUS VivoBook S400C LED Board Replacement: step 5, image 1 of 2 ASUS VivoBook S400C LED Board Replacement: step 5, image 2 of 2
    • Pull out the ribbon cable on the LED side by pulling on the blue tab.
  6. ASUS VivoBook S400C LED Board Replacement: step 6, image 1 of 3 ASUS VivoBook S400C LED Board Replacement: step 6, image 2 of 3 ASUS VivoBook S400C LED Board Replacement: step 6, image 3 of 3
    • The LED board is held in place by a hook on the left end and a latch on the right.
    • Press the latch with a spudger while lifting with a fingernail.
    • Pull the LED board to the right to clear the left-hand hook.
Jerry Wheeler
60,257 Reputation
69 Guides authored
Oregonians Member of Oregonians
Community
8 Members
181 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 61
