ASUS VivoBook S400C SSD Card Replacement
  1. ASUS VivoBook S400C SSD Card Replacement, Remove the Bottom Cover: step 1, image 1 of 1
    • Flip the device over and remove the ten 5.7 mm screws with a Phillips #0 screwdriver.
  2. ASUS VivoBook S400C SSD Card Replacement: step 2, image 1 of 2 ASUS VivoBook S400C SSD Card Replacement: step 2, image 2 of 2
    • Use a spudger or your fingers to go around and lift the edges and release the back panel.
  3. ASUS VivoBook S400C SSD Card Replacement, Disconnect the Battery: step 3, image 1 of 1
    • Using a spudger, lift up the plug connecting the battery to the motherboard.
  4. ASUS VivoBook S400C SSD Card Replacement, SSD Card: step 4, image 1 of 3 ASUS VivoBook S400C SSD Card Replacement, SSD Card: step 4, image 2 of 3 ASUS VivoBook S400C SSD Card Replacement, SSD Card: step 4, image 3 of 3
    • Disconnect the I/O Board ribbon cable from the motherboard.
    • Flip up the retaining latch with a spudger.
  5. ASUS VivoBook S400C SSD Card Replacement: step 5, image 1 of 2 ASUS VivoBook S400C SSD Card Replacement: step 5, image 2 of 2
    • Grasp the ribbon cable by the blue tab and pull it straight out from the connector.
  6. ASUS VivoBook S400C SSD Card Replacement: step 6, image 1 of 3 ASUS VivoBook S400C SSD Card Replacement: step 6, image 2 of 3 ASUS VivoBook S400C SSD Card Replacement: step 6, image 3 of 3
    • Disconnect the I/O Board ribbon cable from the I/O board.
    • Flip up the latch with a spudger.
  7. ASUS VivoBook S400C SSD Card Replacement: step 7, image 1 of 3 ASUS VivoBook S400C SSD Card Replacement: step 7, image 2 of 3 ASUS VivoBook S400C SSD Card Replacement: step 7, image 3 of 3
    • Remove the ribbon cable to expose the SSD device.
  8. ASUS VivoBook S400C SSD Card Replacement: step 8, image 1 of 1
    • If present, remove any insulating sheet covering the SSD.
    • Remove the single retaining screw.
  9. ASUS VivoBook S400C SSD Card Replacement, Unplug the SSD from the motherboard: step 9, image 1 of 2 ASUS VivoBook S400C SSD Card Replacement, Unplug the SSD from the motherboard: step 9, image 2 of 2
    • Grasp the SSD by the sides and slide it out of the connector.
Jerry Wheeler
60,257 Reputation
69 Guides authored
Oregonians Member of Oregonians
Community
8 Members
181 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 25
All Time: 1,127
