ASUS VivoBook S400C Trackpad Replacement
  1. ASUS VivoBook S400C Trackpad Replacement, Remove the Bottom Cover: step 1, image 1 of 1
    • Flip the device over and remove the ten 5.7 mm screws with a Phillips #0 screwdriver.
  2. ASUS VivoBook S400C Trackpad Replacement: step 2, image 1 of 2 ASUS VivoBook S400C Trackpad Replacement: step 2, image 2 of 2
    • Use a spudger or your fingers to go around and lift the edges and release the back panel.
  3. ASUS VivoBook S400C Trackpad Replacement, Disconnect the Battery: step 3, image 1 of 1
    • Using a spudger, lift up the plug connecting the battery to the motherboard.
  4. ASUS VivoBook S400C Trackpad Replacement, Battery: step 4, image 1 of 1
    • With a Phillips #0 screwdriver, remove the four 5.7 mm screws holding the battery to the laptop.
  5. ASUS VivoBook S400C Trackpad Replacement: step 5, image 1 of 1
    • Carefully lift the battery up and out of the device.
  6. ASUS VivoBook S400C Trackpad Replacement, Hard Drive: step 6, image 1 of 1
    • Remove the three Phillips #0 screws holding the the hard drive in place:
    • Two 3.8 mm screws.
    • One 5.7 mm screw.
  7. ASUS VivoBook S400C Trackpad Replacement: step 7, image 1 of 1
    • Pull left and lift out the hard drive.
  8. ASUS VivoBook S400C Trackpad Replacement, Heat Shield: step 8, image 1 of 2 ASUS VivoBook S400C Trackpad Replacement, Heat Shield: step 8, image 2 of 2
    • Remove the black shield covering the display connector and the heat sink.
    • You may need to use double-sided adhesive tape to resecure the shield.
  9. ASUS VivoBook S400C Trackpad Replacement, Display Assembly: step 9, image 1 of 1
    • Remove the black tape securing the keyboard ribbon cable to the display connector.
    • Fold the ribbon cable the opposite way, resecuring it to the hard drive to keep it out of the way.
  10. ASUS VivoBook S400C Trackpad Replacement: step 10, image 1 of 2 ASUS VivoBook S400C Trackpad Replacement: step 10, image 2 of 2
    • Peel off the clear tape from the motherboard display connector.
  11. ASUS VivoBook S400C Trackpad Replacement: step 11, image 1 of 2 ASUS VivoBook S400C Trackpad Replacement: step 11, image 2 of 2
    • Position spudgers on the white tabs on either side of the connector and push evenly to unplug the display.
  12. ASUS VivoBook S400C Trackpad Replacement: step 12, image 1 of 3 ASUS VivoBook S400C Trackpad Replacement: step 12, image 2 of 3 ASUS VivoBook S400C Trackpad Replacement: step 12, image 3 of 3
    • Peel off the three pieces of black tape securing the display cable to the motherboard.
    • Deroute the cable from the channel it sits in.
    • Move the cable to the side, out of the way.
  13. ASUS VivoBook S400C Trackpad Replacement: step 13, image 1 of 3 ASUS VivoBook S400C Trackpad Replacement: step 13, image 2 of 3 ASUS VivoBook S400C Trackpad Replacement: step 13, image 3 of 3
    • Use a spudger to release the cables from the wifi card.
  14. ASUS VivoBook S400C Trackpad Replacement: step 14, image 1 of 3 ASUS VivoBook S400C Trackpad Replacement: step 14, image 2 of 3 ASUS VivoBook S400C Trackpad Replacement: step 14, image 3 of 3
    • Lift the tapes securing the wires to the motherboard.
    • Move the wires to the side out of the way.
  15. ASUS VivoBook S400C Trackpad Replacement, Disconnect the Hinges: step 15, image 1 of 2 ASUS VivoBook S400C Trackpad Replacement, Disconnect the Hinges: step 15, image 2 of 2
    • Remove the two screws securing the hinge on the left.
    • Pry the hinge up by hand to a 90 degree angle.
  16. ASUS VivoBook S400C Trackpad Replacement: step 16, image 1 of 2 ASUS VivoBook S400C Trackpad Replacement: step 16, image 2 of 2
    • Remove the two screws securing the hinge on the right.
  17. ASUS VivoBook S400C Trackpad Replacement, Remove the Display: step 17, image 1 of 3 ASUS VivoBook S400C Trackpad Replacement, Remove the Display: step 17, image 2 of 3 ASUS VivoBook S400C Trackpad Replacement, Remove the Display: step 17, image 3 of 3
    • Lift the base of the laptop from the front.
    • Raise it to a 90 degree angle.
    • Slide it forward slightly to clear the hinges.
    • The display is now free.
  18. ASUS VivoBook S400C Trackpad Replacement, SSD Card: step 18, image 1 of 3 ASUS VivoBook S400C Trackpad Replacement, SSD Card: step 18, image 2 of 3 ASUS VivoBook S400C Trackpad Replacement, SSD Card: step 18, image 3 of 3
    • Disconnect the I/O Board ribbon cable from the motherboard.
    • Flip up the retaining latch with a spudger.
  19. ASUS VivoBook S400C Trackpad Replacement: step 19, image 1 of 2 ASUS VivoBook S400C Trackpad Replacement: step 19, image 2 of 2
    • Grasp the ribbon cable by the blue tab and pull it straight out from the connector.
  20. ASUS VivoBook S400C Trackpad Replacement: step 20, image 1 of 3 ASUS VivoBook S400C Trackpad Replacement: step 20, image 2 of 3 ASUS VivoBook S400C Trackpad Replacement: step 20, image 3 of 3
    • Disconnect the I/O Board ribbon cable from the I/O board.
    • Flip up the latch with a spudger.
  21. ASUS VivoBook S400C Trackpad Replacement: step 21, image 1 of 3 ASUS VivoBook S400C Trackpad Replacement: step 21, image 2 of 3 ASUS VivoBook S400C Trackpad Replacement: step 21, image 3 of 3
    • Remove the ribbon cable to expose the SSD device.
  22. ASUS VivoBook S400C Trackpad Replacement: step 22, image 1 of 1
    • If present, remove any insulating sheet covering the SSD.
    • Remove the single retaining screw.
  23. ASUS VivoBook S400C Trackpad Replacement, Unplug the SSD from the motherboard: step 23, image 1 of 2 ASUS VivoBook S400C Trackpad Replacement, Unplug the SSD from the motherboard: step 23, image 2 of 2
    • Grasp the SSD by the sides and slide it out of the connector.
  24. ASUS VivoBook S400C Trackpad Replacement, Fan / Heatsink Assembly: step 24, image 1 of 1
    • The fan and heat sink do not need to be removed for this procedure.
    • Remove the screw securing the fan to the palm rest. All other fan and heatsink screws can remain in place.
  25. ASUS VivoBook S400C Trackpad Replacement, Motherboard: step 25, image 1 of 3 ASUS VivoBook S400C Trackpad Replacement, Motherboard: step 25, image 2 of 3 ASUS VivoBook S400C Trackpad Replacement, Motherboard: step 25, image 3 of 3
    • Unplug the black cable connecting the motherboard to the speakers.
  26. ASUS VivoBook S400C Trackpad Replacement, Disconnect the Trackpad: step 26, image 1 of 3 ASUS VivoBook S400C Trackpad Replacement, Disconnect the Trackpad: step 26, image 2 of 3 ASUS VivoBook S400C Trackpad Replacement, Disconnect the Trackpad: step 26, image 3 of 3
    • Flip up the trackpad ribbon cable retainer with a spudger.
  27. ASUS VivoBook S400C Trackpad Replacement: step 27, image 1 of 3 ASUS VivoBook S400C Trackpad Replacement: step 27, image 2 of 3 ASUS VivoBook S400C Trackpad Replacement: step 27, image 3 of 3
    • Pull the cable straight out from the connector.
    • Peel the trackpad cable off the conductive tape strip below it.
  28. ASUS VivoBook S400C Trackpad Replacement: step 28, image 1 of 2 ASUS VivoBook S400C Trackpad Replacement: step 28, image 2 of 2
    • Remove the first of the two conductive tapes grounding the trackpad.
  29. ASUS VivoBook S400C Trackpad Replacement: step 29, image 1 of 2 ASUS VivoBook S400C Trackpad Replacement: step 29, image 2 of 2
    • Remove the second conductive tape grounding the trackpad.
  30. ASUS VivoBook S400C Trackpad Replacement, Disconnect the LED Board Cable: step 30, image 1 of 3 ASUS VivoBook S400C Trackpad Replacement, Disconnect the LED Board Cable: step 30, image 2 of 3 ASUS VivoBook S400C Trackpad Replacement, Disconnect the LED Board Cable: step 30, image 3 of 3
    • Use a spudger to flip up the LED board cable retainer.
  31. ASUS VivoBook S400C Trackpad Replacement: step 31, image 1 of 2 ASUS VivoBook S400C Trackpad Replacement: step 31, image 2 of 2
    • Pull the ribbon cable straight out from the connector.
  32. ASUS VivoBook S400C Trackpad Replacement, Disconnect the Keyboard: step 32, image 1 of 3 ASUS VivoBook S400C Trackpad Replacement, Disconnect the Keyboard: step 32, image 2 of 3 ASUS VivoBook S400C Trackpad Replacement, Disconnect the Keyboard: step 32, image 3 of 3
    • Place a spudger on the ears on either side of the keyboard ribbon cable connector and push evenly on both sides to release it.
    • The retainer will only move a very short distance then stop.
    • Lift it slightly to relieve the tension.
  33. ASUS VivoBook S400C Trackpad Replacement: step 33, image 1 of 2 ASUS VivoBook S400C Trackpad Replacement: step 33, image 2 of 2
    • Unplug the keyboard ribbon cable.
  34. ASUS VivoBook S400C Trackpad Replacement, Remove the Mounting Screws: step 34, image 1 of 1
    • Remove the two mounting screws.
    • There are triangular arrows printed on the board pointing to each of them.
  35. ASUS VivoBook S400C Trackpad Replacement, Remove the Motherboard: step 35, image 1 of 2 ASUS VivoBook S400C Trackpad Replacement, Remove the Motherboard: step 35, image 2 of 2
    • Lift and slide the motherboard toward the hard drive to clear the connectors on the opposite side from the case.
  36. ASUS VivoBook S400C Trackpad Replacement, Trackpad: step 36, image 1 of 3 ASUS VivoBook S400C Trackpad Replacement, Trackpad: step 36, image 2 of 3 ASUS VivoBook S400C Trackpad Replacement, Trackpad: step 36, image 3 of 3
    • Flip the retaining latch on the trackpad ribbon cable connector up with a spudger.
  37. ASUS VivoBook S400C Trackpad Replacement: step 37, image 1 of 2 ASUS VivoBook S400C Trackpad Replacement: step 37, image 2 of 2
    Tool used on this step:
    Buy
    • Grasp the blue tab with fine tip tweezers and pull the cable straight out from the connector.
    • Gently peel the trackpad ribbon cable off the trackpad.
  38. ASUS VivoBook S400C Trackpad Replacement, Remove the Trackpad: step 38, image 1 of 2 ASUS VivoBook S400C Trackpad Replacement, Remove the Trackpad: step 38, image 2 of 2
    • Lift the side of the trackpad farthest from the side of the case and slide it away from the edge to remove it.
Jerry Wheeler
60,257 Reputation
69 Guides authored
Oregonians Member of Oregonians
Community
8 Members
181 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 246
