ASUS VivoBook S400C Wifi Card Replacement
  1. ASUS VivoBook S400C Wifi Card Replacement, Remove the Bottom Cover: step 1, image 1 of 1
    • Flip the device over and remove the ten 5.7 mm screws with a Phillips #0 screwdriver.
  2. ASUS VivoBook S400C Wifi Card Replacement: step 2, image 1 of 2 ASUS VivoBook S400C Wifi Card Replacement: step 2, image 2 of 2
    • Use a spudger or your fingers to go around and lift the edges and release the back panel.
  3. ASUS VivoBook S400C Wifi Card Replacement, Disconnect the Battery: step 3, image 1 of 1
    • Using a spudger, lift up the plug connecting the battery to the motherboard.
  4. ASUS VivoBook S400C Wifi Card Replacement, Wifi Card: step 4, image 1 of 2 ASUS VivoBook S400C Wifi Card Replacement, Wifi Card: step 4, image 2 of 2
    • Use a spudger to release the cables from the wifi card.
  5. ASUS VivoBook S400C Wifi Card Replacement: step 5, image 1 of 1
    • Remove the singular 3.8 mm screw with a Phillips #0 screwdriver.
  6. ASUS VivoBook S400C Wifi Card Replacement: step 6, image 1 of 1
    • Pull the wifi card up and out.
Ashley Panduro
572 Reputation
3 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 22
All Time: 793
