ASUS Vivobook Q301LA-BSI5T17 Charging Port Replacement
  1. ASUS Vivobook Q301LA-BSI5T17 Charging Port Replacement, Battery: step 1, image 1 of 1
    • Unscrew the (10) screws on the bottom of the computer chassis using the JIS #0 screwdriver.
  2. ASUS Vivobook Q301LA-BSI5T17 Charging Port Replacement: step 2, image 1 of 2 ASUS Vivobook Q301LA-BSI5T17 Charging Port Replacement: step 2, image 2 of 2
    • Slightly lift the lower case and push it toward the rear of the computer to free the mounting tabs.
  3. ASUS Vivobook Q301LA-BSI5T17 Charging Port Replacement: step 3, image 1 of 3 ASUS Vivobook Q301LA-BSI5T17 Charging Port Replacement: step 3, image 2 of 3 ASUS Vivobook Q301LA-BSI5T17 Charging Port Replacement: step 3, image 3 of 3
    • Remove the (6) six screws attaching the battery to the frame using the JIS #0 screwdriver.
    • Use the black plastic spudger to remove the battery from the device.
  4. ASUS Vivobook Q301LA-BSI5T17 Charging Port Replacement: step 4, image 1 of 3 ASUS Vivobook Q301LA-BSI5T17 Charging Port Replacement: step 4, image 2 of 3 ASUS Vivobook Q301LA-BSI5T17 Charging Port Replacement: step 4, image 3 of 3
    • Gently take the battery out of the laptop, making sure that all wires connecting to it are disconnected.
  5. Careful: steps 5-6 are sourced from a guide that's marked as in-progress.
    ASUS Vivobook Q301LA-BSI5T17 Charging Port Replacement, Motherboard: step 5, image 1 of 2 ASUS Vivobook Q301LA-BSI5T17 Charging Port Replacement, Motherboard: step 5, image 2 of 2
    • When removing the cooling fan, carefully unplug the cable that is connected to the motherboard.
    • Once you have carefully unplugged the cable, the cooling fan should just come off with ease.
  6. ASUS Vivobook Q301LA-BSI5T17 Charging Port Replacement: step 6, image 1 of 2 ASUS Vivobook Q301LA-BSI5T17 Charging Port Replacement: step 6, image 2 of 2
    • Carefully remove the motherboard.
    • You can now replace it with a new motherboard or perform any necessary modifications to it.
  7. ASUS Vivobook Q301LA-BSI5T17 Charging Port Replacement, Charging Port: step 7, image 1 of 1
Jens Peter Andersen
658 Reputation
6 Guides authored
USF Tampa, Team S5-G1, Walkup Fall 2017 Member of USF Tampa, Team S5-G1, Walkup Fall 2017
USFT-WALKUP-F17S5G1
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 13
All Time: 1,028
