ASUS Vivobook Q301LA-BSI5T17 Fan/Heatsink Replacement
  1. ASUS Vivobook Q301LA-BSI5T17 Fan/Heatsink Replacement, Back Case Housing: step 1, image 1 of 1
    • Remove all ten 6mm Phillips #1 screws from the bottom of the computer chassis.
  2. ASUS Vivobook Q301LA-BSI5T17 Fan/Heatsink Replacement: step 2, image 1 of 1
    • Carefully pry open the back cover from the laptop and place it to the side.
  3. ASUS Vivobook Q301LA-BSI5T17 Fan/Heatsink Replacement, Fan: step 3, image 1 of 1
    • Remove three 5mm Phillips #1 screws that are holding the fan in place.
  4. ASUS Vivobook Q301LA-BSI5T17 Fan/Heatsink Replacement: step 4, image 1 of 2 ASUS Vivobook Q301LA-BSI5T17 Fan/Heatsink Replacement: step 4, image 2 of 2
    • Carefully unplug the fan cable from the motherboard using a spudger or plastic opening tool.
  5. ASUS Vivobook Q301LA-BSI5T17 Fan/Heatsink Replacement: step 5, image 1 of 2 ASUS Vivobook Q301LA-BSI5T17 Fan/Heatsink Replacement: step 5, image 2 of 2
    • Carefully use your hands to remove the fan by pulling it from the heatsink housing.
    • Do not use excessive force; there is a potential to break the plastic.
Amrinder Singh
277 Reputation
3 Guides authored
IUPUI, Team S1-G2, Hovde Spring 2019 Member of IUPUI, Team S1-G2, Hovde Spring 2019
IUPUI-HOVDE-S19S1G2
3 Members
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 302
