ASUS Vivobook Q301LA-BSI5T17 Hard Drive Replacement
  1. ASUS Vivobook Q301LA-BSI5T17 Hard Drive Replacement, Battery: step 1, image 1 of 1
    • Unscrew the (10) screws on the bottom of the computer chassis using the JIS #0 screwdriver.
  2. ASUS Vivobook Q301LA-BSI5T17 Hard Drive Replacement: step 2, image 1 of 2 ASUS Vivobook Q301LA-BSI5T17 Hard Drive Replacement: step 2, image 2 of 2
    • Slightly lift the lower case and push it toward the rear of the computer to free the mounting tabs.
  3. ASUS Vivobook Q301LA-BSI5T17 Hard Drive Replacement: step 3, image 1 of 3 ASUS Vivobook Q301LA-BSI5T17 Hard Drive Replacement: step 3, image 2 of 3 ASUS Vivobook Q301LA-BSI5T17 Hard Drive Replacement: step 3, image 3 of 3
    • Remove the (6) six screws attaching the battery to the frame using the JIS #0 screwdriver.
    • Use the black plastic spudger to remove the battery from the device.
  4. ASUS Vivobook Q301LA-BSI5T17 Hard Drive Replacement: step 4, image 1 of 3 ASUS Vivobook Q301LA-BSI5T17 Hard Drive Replacement: step 4, image 2 of 3 ASUS Vivobook Q301LA-BSI5T17 Hard Drive Replacement: step 4, image 3 of 3
    • Gently take the battery out of the laptop, making sure that all wires connecting to it are disconnected.
  5. ASUS Vivobook Q301LA-BSI5T17 Hard Drive Replacement, Hard Drive: step 5, image 1 of 2 ASUS Vivobook Q301LA-BSI5T17 Hard Drive Replacement, Hard Drive: step 5, image 2 of 2
    • Gently pull on the hard drive bay to disconnect it from the motherboard.
Jens Peter Andersen
658 Reputation
6 Guides authored
USF Tampa, Team S5-G1, Walkup Fall 2017 Member of USF Tampa, Team S5-G1, Walkup Fall 2017
USFT-WALKUP-F17S5G1
4 Members
6 Guides authored
One Comment
Vorrei installare un secondo hdd al posto del lettore cd. Devo comprare un HDD Caddy, che ha ha il lettore cd? Con quali caratteristiche รจ comprensarlo? GRAZIE
Antonio Leanza - Reply
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 28
All Time: 3,044
