ASUS Vivobook Q301LA-BSI5T17 Memory Card Replacement
  1. ASUS Vivobook Q301LA-BSI5T17 Memory Card Replacement, Back Case Housing: step 1, image 1 of 1
    • Remove all ten 6mm Phillips #1 screws from the bottom of the computer chassis.
  2. ASUS Vivobook Q301LA-BSI5T17 Memory Card Replacement: step 2, image 1 of 1
    • Carefully pry open the back cover from the laptop and place it to the side.
  3. ASUS Vivobook Q301LA-BSI5T17 Memory Card Replacement, Memory Card: step 3, image 1 of 2 ASUS Vivobook Q301LA-BSI5T17 Memory Card Replacement, Memory Card: step 3, image 2 of 2
    • Lift the perforated metal cover up from the motherboard to expose the memory cards.
  4. ASUS Vivobook Q301LA-BSI5T17 Memory Card Replacement: step 4, image 1 of 2 ASUS Vivobook Q301LA-BSI5T17 Memory Card Replacement: step 4, image 2 of 2
    • Once the cover is removed the RAM will be accessible.
    • Use your fingertips to pry out the metal guards outlining both of the sides of the memory card.
    • The RAM stick should then pop up to rest at an angle to the motherboard.
  5. ASUS Vivobook Q301LA-BSI5T17 Memory Card Replacement: step 5, image 1 of 1
    • Using your fingertips, slide the memory card out from the plastic housing and remove it from the board.
    • Be sure to remove the card at the same angle at which it rests to avoid damaging the card or the contacts of the slot.
Mark Fanelli
97 Reputation
1 Guide authored
IUPUI, Team S1-G2, Hovde Spring 2019 Member of IUPUI, Team S1-G2, Hovde Spring 2019
IUPUI-HOVDE-S19S1G2
3 Members
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 437
