ASUS Vivobook Q301LA-BSI5T17 WIFI CHIP Replacement
  1. ASUS Vivobook Q301LA-BSI5T17 WIFI CHIP Replacement, Back Case Housing: step 1, image 1 of 1
    • Remove all ten 6mm Phillips #1 screws from the bottom of the computer chassis.
  2. ASUS Vivobook Q301LA-BSI5T17 WIFI CHIP Replacement: step 2, image 1 of 1
    • Carefully pry open the back cover from the laptop and place it to the side.
  3. ASUS Vivobook Q301LA-BSI5T17 WIFI CHIP Replacement, WIFI CHIP: step 3, image 1 of 3 ASUS Vivobook Q301LA-BSI5T17 WIFI CHIP Replacement, WIFI CHIP: step 3, image 2 of 3 ASUS Vivobook Q301LA-BSI5T17 WIFI CHIP Replacement, WIFI CHIP: step 3, image 3 of 3
    • Locate the wifi module on the back of your laptop.
    • Use an iFixit opening tool to pry the black (Main) and the white (Aux) coaxial cable connectors upward.
  4. ASUS Vivobook Q301LA-BSI5T17 WIFI CHIP Replacement: step 4, image 1 of 1
    • Remove the 5mm screw from the module using the Phillips PH1 screwdriver.
  5. ASUS Vivobook Q301LA-BSI5T17 WIFI CHIP Replacement: step 5, image 1 of 1
    • Gently pull the WiFi module out of its housing from the motherboard.
    • Careful not to break or bend the metal contacts.
Amrinder Singh
277 Reputation
3 Guides authored
IUPUI, Team S1-G2, Hovde Spring 2019 Member of IUPUI, Team S1-G2, Hovde Spring 2019
IUPUI-HOVDE-S19S1G2
3 Members
4 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 10
All Time: 699
