ASUS Vivobook S500CA Battery Replacement
  1. ASUS Vivobook S500CA Battery Replacement, Battery: step 1, image 1 of 1
    • Turn the device over to where the back plate is facing up.
  2. ASUS Vivobook S500CA Battery Replacement: step 2, image 1 of 1
    • Use a Philips Head PH1 screwdriver to remove 10 screws (3 1cm screws and 7 .5cm screws) around the perimeter of the back plate.
    • Place screws where they cannot be lost as they will be used to replace the back plate.
  3. ASUS Vivobook S500CA Battery Replacement: step 3, image 1 of 1
    • Remove the back plate by lifting it straight up.
  4. ASUS Vivobook S500CA Battery Replacement: step 4, image 1 of 1
    • Remove 9 (.5 cm) phillips screws around the edge of the battery.
  5. ASUS Vivobook S500CA Battery Replacement: step 5, image 1 of 1
    • Lift up the battery to reveal the battery terminal.
  6. ASUS Vivobook S500CA Battery Replacement: step 6, image 1 of 1
    • Unclip the battery terminal by prying straight up on the sides of the connector to release the clip.
Deric Huffman
101 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 16
All Time: 6,043
