ASUS X502CA Battery Replacement
  1. ASUS X502CA Battery Replacement, Palm Rest with Keyboard and Touch Pad: step 1, image 1 of 1
    • Use the Phillips #00 screwdriver to remove the seven 90mm screws.
    • Use the Phillips #00 screwdriver to remove the four 50mm screws.
  2. ASUS X502CA Battery Replacement: step 2, image 1 of 1
    • Next, use the plastic opening tool to carefully pop off the keyboard cover panel.
    • Be cautious when pulling off the cover because there are cables you will have to disconnect before completely removing the panel.
  3. ASUS X502CA Battery Replacement: step 3, image 1 of 2 ASUS X502CA Battery Replacement: step 3, image 2 of 2
    Tool used on this step:
    Buy
    • Lift palm rest and unplug keyboard cable and touchpad cable using tweezers. After these two cables have been unplugged you can remove the keyboard cover panel.
  4. ASUS X502CA Battery Replacement: step 4, image 1 of 2 ASUS X502CA Battery Replacement: step 4, image 2 of 2
    • Lift Palm Rest away.
    • Replace with new palm rest.
  5. ASUS X502CA Battery Replacement, Battery: step 5, image 1 of 1
    • Next, locate the battery in the front of laptop (closest to you).
  6. ASUS X502CA Battery Replacement: step 6, image 1 of 1
    Buy
    • Unplug the battery from the laptop in the upper right hand corner of the battery using tweezers.
    • If battery is not unplugged, motherboard may shock you.
  7. ASUS X502CA Battery Replacement: step 7, image 1 of 2 ASUS X502CA Battery Replacement: step 7, image 2 of 2
    • Use the Phillips #00 Screwdriver to carefully remove the 6 screws holding the battery in place.
    • Once you have removed all six screws carefully lift the battery out and dispose.
    • Each screw is 50 mm in length and 15 mm in diameter.
5 other people completed this guide.
David Conner
292 Reputation
2 Guides authored
Clemson, Team 14-1, Shirley Winter 2015 Member of Clemson, Team 14-1, Shirley Winter 2015
CLEM-SHIRLEY-W15S14G1
5 Members
5 Guides authored
1 Guide Comment
Thank you for posting this
SteveFFFFF 0 - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 8
All Time: 14,989
