ASUS X502CA Palm Rest with Keyboard and Touch Pad Replacement
  1. ASUS X502CA Palm Rest with Keyboard and Touch Pad Replacement, Palm Rest with Keyboard and Touch Pad: step 1, image 1 of 1
    • Use the Phillips #00 screwdriver to remove the seven 90mm screws.
    • Use the Phillips #00 screwdriver to remove the four 50mm screws.
  2. ASUS X502CA Palm Rest with Keyboard and Touch Pad Replacement: step 2, image 1 of 1
    • Next, use the plastic opening tool to carefully pop off the keyboard cover panel.
    • Be cautious when pulling off the cover because there are cables you will have to disconnect before completely removing the panel.
  3. ASUS X502CA Palm Rest with Keyboard and Touch Pad Replacement: step 3, image 1 of 2 ASUS X502CA Palm Rest with Keyboard and Touch Pad Replacement: step 3, image 2 of 2
    Tool used on this step:
    Buy
    • Lift palm rest and unplug keyboard cable and touchpad cable using tweezers. After these two cables have been unplugged you can remove the keyboard cover panel.
  4. ASUS X502CA Palm Rest with Keyboard and Touch Pad Replacement: step 4, image 1 of 2 ASUS X502CA Palm Rest with Keyboard and Touch Pad Replacement: step 4, image 2 of 2
    • Lift Palm Rest away.
    • Replace with new palm rest.
5 other people completed this guide.
Michael Morrow
258 Reputation
1 Guide authored
Clemson, Team 14-1, Shirley Winter 2015 Member of Clemson, Team 14-1, Shirley Winter 2015
CLEM-SHIRLEY-W15S14G1
5 Members
5 Guides authored
One Comment
there is no reason to disassemble the top-half of the laptop.
seanwilson684 - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 7
All Time: 1,922
