ASUS X533SA-BHCLN10 Battery Replacement
  1. ASUS X533SA-BHCLN10 Battery Replacement, Battery: step 1, image 1 of 2 ASUS X533SA-BHCLN10 Battery Replacement, Battery: step 1, image 2 of 2
    • Turn over the laptop on the back panel.
    • Use the Phillips #0 screwdriver to unscrew all ten screws visible on the back panel. There should be a total of ten screws: (4) four 5.5mm screws and (6) six 10.5mm screws.
  2. ASUS X533SA-BHCLN10 Battery Replacement: step 2, image 1 of 2 ASUS X533SA-BHCLN10 Battery Replacement: step 2, image 2 of 2
    • Turn over the laptop with the keyboard facing upwards.
    • Using a small prying or opening tool, stick the prying tool under the edge of the laptop.
  3. ASUS X533SA-BHCLN10 Battery Replacement: step 3, image 1 of 2 ASUS X533SA-BHCLN10 Battery Replacement: step 3, image 2 of 2
    • After the laptop is completely pried open carefully remove the keyboard from the laptop.
    • There are two small keyboard cables connecting the keyboard to the laptop. Carefully remove these by popping up the white clips holding them in place and slide the connector out.
3 other people completed this guide.
Edmund Lee
473 Reputation
4 Guides authored
USF Tampa, Team S13-G3, Boczar Fall 2017 Member of USF Tampa, Team S13-G3, Boczar Fall 2017
USFT-BOCZAR-F17S13G3
5 Members
5 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 14
All Time: 655
