ASUS X533SA-BHCLN10 LCD Screen Replacement
Video Overview
  1. ASUS X533SA-BHCLN10 LCD Screen Replacement, LCD Screen: step 1, image 1 of 2 ASUS X533SA-BHCLN10 LCD Screen Replacement, LCD Screen: step 1, image 2 of 2
    • Power off laptop.
    • Flip over the laptop so the model stickers are pointing towards the ceiling, and the back of the laptop is facing you.
  2. ASUS X533SA-BHCLN10 LCD Screen Replacement: step 2, image 1 of 3 ASUS X533SA-BHCLN10 LCD Screen Replacement: step 2, image 2 of 3 ASUS X533SA-BHCLN10 LCD Screen Replacement: step 2, image 3 of 3
    • Carefully insert a plastic opening tool into the top edge of the plastic cover. Slowly run the tool along the top edge to allow several small plastic clips to release.
    • Lift the plastic cover off and set it aside.
  3. ASUS X533SA-BHCLN10 LCD Screen Replacement: step 3, image 1 of 3 ASUS X533SA-BHCLN10 LCD Screen Replacement: step 3, image 2 of 3 ASUS X533SA-BHCLN10 LCD Screen Replacement: step 3, image 3 of 3
    Tool used on this step:
    Buy
    • Using tweezers, remove the (2) two magnetic tabs covering the screws on the screen.
  4. ASUS X533SA-BHCLN10 LCD Screen Replacement: step 4, image 1 of 3 ASUS X533SA-BHCLN10 LCD Screen Replacement: step 4, image 2 of 3 ASUS X533SA-BHCLN10 LCD Screen Replacement: step 4, image 3 of 3
    • Use a JIS #0 screwdriver to remove the two 4.5mm screws.
  5. ASUS X533SA-BHCLN10 LCD Screen Replacement: step 5, image 1 of 2 ASUS X533SA-BHCLN10 LCD Screen Replacement: step 5, image 2 of 2
    • Insert a plastic opening tool under the edge of the laptop lid.
    • Carefully pop out the sides of the laptop by running the plastic opening tool along the edge.
  6. ASUS X533SA-BHCLN10 LCD Screen Replacement: step 6, image 1 of 2 ASUS X533SA-BHCLN10 LCD Screen Replacement: step 6, image 2 of 2
    • Use a JIS #0 screwdriver to unscrew the four 3.5mm screws.
  7. ASUS X533SA-BHCLN10 LCD Screen Replacement: step 7, image 1 of 3 ASUS X533SA-BHCLN10 LCD Screen Replacement: step 7, image 2 of 3 ASUS X533SA-BHCLN10 LCD Screen Replacement: step 7, image 3 of 3
    • Carefully lift up the LCD screen.
    • Carefully remove the cable connecting the LCD to the laptop by popping up the white clip on the laptop and sliding the connector out.
Spencer Lee
268 Reputation
2 Guides authored
IUPUI, Team S2-G4, Harley Fall 2018 Member of IUPUI, Team S2-G4, Harley Fall 2018
IUPUI-HARLEY-F18S2G4
3 Members
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 540
